Need to put the mod list in order
I've tried to read a lot about the common mods and better understand them. I'm trying to put the mod list in order. Keep in mind, this is our work rig and the most important thing is longevity. I do experience turbo surge after the 6637. Hopefully I can start plugging through the mod list this winter.
Mods on the list:
In-tank mods
Wicked wheel
Pedestal o-rings
Boot kit
International bellowed up-pipes
4" exhaust
CCK
HPX
Gauges
AIH Delete
Pipedream mod list:
Adrenalin HPOP
Ball Bearing Turbo
Tuner
Should I install a turbo rebuild kit when I go ahead and install a WW and the pedestal o-rings? Does everything need to be checked for balance after the install, sort of like a wheel and tire? Any other common mod suggestions to add to the list?
Mods on the list:
In-tank mods
Wicked wheel
Pedestal o-rings
Boot kit
4" exhaust
CCK
HPX
Gauges
AIH Delete
Pipedream mod list:
Adrenalin HPOP
Ball Bearing Turbo
Tuner
feel how much play is in the turbo. If there is a lot then go ahead and rebuild it and get it balanced. If it feels nice and tight... just stick the wheel on there.
by the way you could get the whole mod list from Clay at Riffraff Diesel. Shoot him an email. sales@riffraffdiesel.com
re
Mods on the list:
In-tank mods
Wicked wheel
Pedestal o-rings
Boot kit
4" exhaust
CCK
HPX
Gauges
AIH Delete
Pipedream mod list:
Adrenalin HPOP
Ball Bearing Turbo
Tuner
Mods on the list:
In-tank mods
Wicked wheel
Pedestal o-rings
Boot kit
4" exhaust
CCK
HPX
Gauges
AIH Delete
Pipedream mod list:
Adrenalin HPOP
Ball Bearing Turbo
Tuner
Here are some ideas for mods https://www.ford-trucks.com/forums/5...confusion.html look at post 18
I found this last night. I figured I'd run through that to see how things are doing. The WW is a compressor wheel, not a turbine wheel, right? So if everything's tight and looks good, will the different compressor wheel throw off the shaft at all, requiring balancing? Shouldn't the compressor wheel be tested and balanced accordingly before they even sell them? I suppose you could tweak it during installation or tweak the shaft.
I do plan on buying from riffraff.
I would save the gauges, exhaust, and up-pipes until you decide to go with a tuner. If you just want to get ready for a chip or tuner then I would understand. I think you should do the WW asap and let us know how it turns out. I'm in the same boat about the surging issue and plan on doing it soon. I'm not planning on doing a rebuild of the turbo though unless I see problems. Good Luck........
First thing to do is get the thing breathing. You are half way there with the 6637 but to finish it off you need the 4" turbo back exhaust (air in and exhaust out) Surge is not good so the WW will fix that. Im doing the same but Im going to run a rebuild through it as well while I have the turbo off. Check your up-pipes and boots for leaks. Black soot around the uppies are a sign of leaks. CCK, HPX are just to quiten the motor down. The best mod I did was the In Tank mod. Throttle response was very impressive and it did the best job with engine cackle. To me, gauges are a must aswell. You need to know whats happening with your transmission and engine. Pyro - Trans and Boost is what I have. Adrenalin and BB turbo are for maximum HP - Dont know about that for a work truck but each to his own. Im yet to go down the Tuner path but when I do it will be a DP tuner. I do have one of the first Edge programs (tow mode) but it is very basic. Check my sig for other mods . I have ceramic coated uppies - WW - turbo rebuild kit - new boots sitting on my work bench (waiting for enough time). Im also going to get my manifold and turbo exhaust housing coated as well. My aim is to get everything running right and to its best ability before I go for increasing HP. I hope this helps
If your up-pipes are leaking, that's not a mod, that's maintenance. Every single other mod will not be able to fully perform if they are leaking. It's like running around with 30psi in your tires instead of 60psi. Since you are getting surge issues now, the Wicked Wheel is again, maintenance, not necessarily a "mod" as in an upgrade in performance. If your boots are old and/or oil impregnated... same thing. Same for the pedestal o-rings. All 4 should be addressed ASAP if you have leaks. And since you must remove the turbo to do the up-pipes, it's the perfect time to rebuild (if needed) and swap on the WW.
Next in line:
In-tank mods (Hutch & Harpoon - ITP Diesel kit w/filter is what I used)
4" exhaust with muffler - no need to annoy customers with a loud truck idling away
HPX
CCK
Next in line:
HPX
CCK
Next in line:
HPX
CCK
Next in line:
HPX
CCK
GoCamping
03-13-2006 06:59 PM
