86 F-150 upgrades and rebuild.
Hi all. I’ve been working on this project for a few months and have gained a lot of knowledge from this forum. Thought I should contribute with a thread to show some of what I’ve been working on, and what’s coming next. I’m not a mechanic and just learn as I go on that, but I do have a lot of experience in vehicle “upfitting” and automotive electrical. I’m horrible about taking pictures. Especially “before” pictures so bear with me, but I will upload some of what I’ve got. Here is a running list on what I’ve gotten done so far:
Before doing any work. The PO had parked it for 5 years. Tires were dry rotted but very minimal rust. Surface only, have not found any cancerous rust during this entire project.
Bed freshly removed. Was a pita working under there. Decades of mud and dust would fall into your eyes every time you moved or turned a wrench.
Pressure washed, wire brushed entire chassis with brake cleaner, then coated with rustoleum rust converter. Works very well.
New fuel tanks and pumps.
Prepping for rubberized under coating.
Coating applied.
Interior sound deadening. Ended up having enough to do 2 full layers.
Original front end look.
Painting core support behind grille. Didn’t want to see multiple colors behind the new one.
1/2” plywood mounted to rear wall to give a place to mount small powered subwoofer, 6x9 boxes, power inverter etc.
Carpet to hide plywood.
Wheels getting some matte black.
Very rare snow in this part of Texas.
New grille, 1980 style with no emblem. Clear marker light housings
Amber led’s
2 new fuel tanks
2 new fuel pumps and sending units
Cleaned/painted tank mounts/hardware
Replaced all fuel hose retaining clips
New gasket and 180° Thermostat
Painted break drums
Cleaned and “rust-reform” all chassis-behind cab, axle, drive shaft and bumper
Spark plugs and cables
Distributor cap and rotor
Fuel filter
Cleaned/painted parts under hood
Air filter
Oil change and filter
Transmission filter / pan gasket / fluid
Installed central grounding lug
Replaced battery hold-down
Rear shock absorbers
Matte blacked rear bumper
Flushed radiator and coolant system
Restored dome light
Wrapped dash pad
Cleaned/painted ashtray
Sea foam intake cleaner and hot soak
Sea foam HM in fuel and crank case
Cleaned / washed / prepped under bed
Rubberized undercoated entire under bed
High heat painted exhaust heat shields
New glasspack muffler and tailpipe
Installed muffler hanger
Killmat sound deadening entire floorpanx2
Installed 1/2” plywood across rear wall
Killmat plywood (sandwiched between wall)
Killmat rear wall
Carpeted rear wall and plywood
New fitted ford light gray carpet
Saddle blanket type seat cover
Window channel felt and rubbers
New optima yellow top battery
Rebuilt brake drums w/ all new hardware
New rear brake shoes and brake line
New axle vent hose
Self etching primer/matte black wheels
New BF Goodrich A/T tires
ColorBond ford gray interior parts/panels
Matte black door panel trim
Matte black threshold plates
New front shock absorbers
New rubber front brake lines
New front brake calipers (painted)
New front brake pads
Pressure wash and paint front wheel wells
New ignition (tfi) module
New ignition coil
Black paint core support etc behind grille
New 3-core all aluminum radiator
New dual electric cooling fans
mr. gasket radiator thermostat-cap 16psi
Repaired damaged tranny intercooler line
Installed seat heaters
New charcoal canister
New 1980 f150 grill and side bezels
Matte blacked entire front grille area
New clear front marker/signal lights
Cleared clogged throttle body water ports
Topped off rear differential
Lubed/greased u-joints
Installed electric door locks
Repaired “water tree” inlet
Rebuilt heater door with aluminum hinge
Coating applied.
Amber led’s
2 new fuel tanks
Painted break drums
Fuel filter
Air filter
Restored dome light
Wrapped dash pad
Killmat rear wall
New axle vent hose
New ignition coil
The following users liked this post:
Thanks everybody. The rubberized undercoating is just rattle-can rustoleum that is sold at Home Depot etc. I think it took 6 cans to do 2 coats under the bed.
I really like the headlights too. LMC sells them. I wanted LED’s but I didn’t want the truck to look like a space ship. These fit the all-in-one form factor headlight that out trucks use, but actually has a removable/replaceable bulb. The bulbs were just some from amazon. I forget the brand name but I can go look it up if anyone is interested.
npd23
18
03-24-2021 08:18 PM
Connecticut Calvin
47
01-06-2020 12:45 PM
