Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 09-26-2009, 05:38 PM
tdappleman tdappleman is offline
tdappleman is gaining momentum as a positive member of FTE.
ok - that is fantastic!! Have you done any dyno runs or track runs to get an idea of the power and times you can get?
__________________
2003 Excursion EB 4x4 V10, MT ATZ 285/75-16, Hawk LTS pads front & rear with new rotors
2000 Explorer XLT 4x4 - 30k miles
1974 Bronco 4x4 - 302, 3spd, 3.54 LSD front and rear - Restored beach toy
www.coastalfastlube.com
  #17 (permalink)
Old 09-26-2009, 05:45 PM
turbo10 turbo10 is offline
turbo10 is starting off with a positive reputation.
Not Yet, I still have to come up with a PVC system that works with the boost, Right now I can't stay in the boost long because of the factory PVC system. I had back surgery 3 months ago and i'm still recovering. I read somewhere where a guy had a 2wd EX and it made right at 250 RWHP stock. I forget the torque it put down. Hopfully before winter I will get it done.
  #18 (permalink)
Old 09-26-2009, 06:54 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
That's some sick ***** right there!! I freaking love it!
It's too bad your wife wants you to get rid of the setup. It would be nice to follow your build as you work out the bugs and kinks in the system.
Cutting and welding together a set of L headers is a novel idea. They can be easily found too because a lot of us L owners have upgraded to long tubes.
Reminds me of a few years back when the first turbo systems were being fabricated for the L's. Lotta bugs to get worked out.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #19 (permalink)
Old 09-26-2009, 07:36 PM
Stewart, It was Lightning intake manifolds I was cutting in half. The V10 is the same engine as the 5.4 just add 2 more cylinders. So what I am doing with the intakes is cut the back 2 cylinders out of one and the front 2 out of the other. Put them together and you will have a lightning intake with 5 ports on each side. That will bolt right down to the V10 heads. Then the rest is fabricated from there.
  #20 (permalink)
Old 09-26-2009, 07:39 PM
Here is a terrible video of the Ex blasting down the road behind the house. Trust me, there will be better ones to come
  #21 (permalink)
Old 09-26-2009, 08:18 PM
bigrigmike's Avatar
bigrigmike bigrigmike is offline
bigrigmike is starting off with a positive reputation.
I want!! I want!! I want!!!!!!!!!!!!!!!
  #22 (permalink)
Old 09-26-2009, 08:35 PM
Yea, it's great. My buddy was just telling me if I can get the PVC system worked out and keep it from going lean it will be safe at 10lb of boost. I can't wait..
  #23 (permalink)
Old 09-26-2009, 08:38 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Quote:
That's what I get for not reading S L O W E R.......LOL.
Who is tuning the beast for you?
Stewart
__________________
  #24 (permalink)
Old 09-26-2009, 08:42 PM
cbradford's Avatar
cbradford cbradford is offline
2005 Ford Excursion
cbradford is gaining momentum as a positive member of FTE. cbradford is gaining momentum as a positive member of FTE.
Let me know what you gus think.
I think that's pretty cool, hope you get it all worked out and don't take it off.
__________________
Chris
05 Excursion Limited V10, 4:30(C3) Limited Slip
Mods:Front Cyro Power Slot Rotors & Hawk LTS Pads, Moog ball joints, Bilstein Shocks
01 Expy EB, 5.4, 3.55 (H9) Limited Slip
2006 27' Outback T.T. 7000lbs-loaded
  #25 (permalink)
I email tuned it with a guy in California (www.tricktuners.com) It only took me 5 datalogs to get it where it is now. His name is Joe. If you get a chance to go to his site read his bio.. one slick guy...
  #26 (permalink)
Old 09-26-2009, 08:46 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
SCT 2, Predator, a different hand held?
Inquiring minds wanna know!
Stewart
__________________
  #27 (permalink)
How did you guys get your vehicle info and photos in your post? do I not have enough post to do that yet?
Thanks
  #28 (permalink)
Old 09-26-2009, 08:49 PM
I found a used unlocked SCT Xcal II. It worked excellent. I purchased a cable to take my Wideband and EGT readings..
  #29 (permalink)
Old 09-26-2009, 08:57 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
I used to use the Predator to download tunes into my L, but when I switched tuners (human tuner), he didn't use Diablosport programming, so I had to switch to the Xcal II.
I dunno if you have to have over 25 posts in order to have a signature, like you do to use PM's, but maybe you do.
Once you hit 25, look in your User CP and see if the sig button in the left toolbar shows up.
Stewart
PS - I just repped you for this thread. Whenever you find a post you appreciate, whether because it's good tech, a good story, or it makes you laugh, you can rep the person by clicking on the little heart icon to the far right, just above the personal info, ie. join date, location, number of posts.
__________________
  #30 (permalink)
Old 09-26-2009, 08:59 PM
Ok. I'll check it out once I hit 25. Everyone in my area uses the SCT.
Tags
2002 , 30 , 4 , decoder , excursion , f250 , ford , kit , lift , picture , sts , supercharger , torque , turbo , v10 , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
