Need some HVAC help
Any new ideas?
Have a 00 EX and the rear selector works great.
Front manual selectior is not working fan and temp work but the selector is not working. ONLY blows on defrost. Will not change output to pannel or feet.
Took out the glove box and the arm moves a bit but not much at all.
Thinking its the HVAC controller. Anyone else have this problem? Dealer wants 90.00 to let me know what MAY... be wrong.
have you checked the shaft for the blend door. It's made of plastic and known to break.
here is a site that has a fix for it. 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, Ford F250, F350, F450, blend door auto AC heat replacement part
Other wise if it is broking you would need to pull the dash and hvac box.
Blend door was for the OP. For your concern it might be a vacuum problem you could get a vacuum hand pump and try that to see. If you have the Electrical HVAC you will have to check the wiring
If it is the auto climate control hvac controller, they have been known to cause that problem.I would verify it had a vacuum source to it before replacing. Wife had a mercury grandmarquis with the same box and had two in it before it was 4 years old. Ran into the lady that bought it from me during christmas and she mentioned having to replace it again
1great40
06-10-2013 05:34 AM
bankerjohn
12-19-2009 12:41 PM
