Trying to remove Goose Neck Hitch
Anyone have any ideas on how to remove a Goose Neck Hitch? The PO put this one in and I have no need for it.
It looks as though the ball screws directly into the crossmember that is under the bed. There is no nut on the bottom side. I've tried pulling on it with a giagantic pipe wrench but it wouldn't budge. I'm thinking maybe a 8ft cheater bar would help....
This is my first experience messing with one of these so I thought I would seek advice in case there is some weird trick to it.
I'll add some pictures once the sun comes up.
where are you? I'm looking for a GN hitch.. I am near austin tx.
Sam
Sam, My truck came with a B&W Turnover ball set up, which I don't use. I've thought of taking it off, but it seems like a lot of hassle for no good reason.
Is it worth anything to you?
I am just North of Houston...
We have a few thread ins that just don't come out after years of being left in. If you can get a torch to the bottom it would probably break the rust loose but between the tanks and the tight spaces I am assuming that won't be possible. Worst case if you want it out and don't ever plan on using it cut it out from the top.
hitch
just bought a truck with same problem,didnt need the hitch and had to have it burnt off and ground off smooth,if i ever need i hitch i will have to replace the whole thing,If you do this be careful not to burn bed ,might be better if you can cut it with a saw zaw and then grind it with a big grinder. Jim
