289 to 302 questions
#31
Yes. Those would all be 28oz imbalance parts.
The 6 bolts that are referred to earlier, in previous posts, are the bellhousing to block, not the flywheel, just to be clear. Both the 28 and 50 oz flywheels/flexplates have the same bolt parrern, so they physically interchange (even though they shouldn't, imo, and would help with eliminating a lot of confusion if they didn't), but not dynamically.
#32
Sorry yes it is the bellhousing 6 bolt also. I guess I'm on my way again.
So now what I'm using on my 1980 block is my 1980 timing chain cover with the cast water pump and 1972 Comet flywheel. I'm using my 28oz. skinny harmonic balancer from the 289 with the 3 bolt pulley. The top pulley will be the 289 one also with a little shimming to line up belt since my 302 pump sticks out farther than the 289 set up. Hopefully all goes well.
Thanks for the help. We'll keep you informed.....and maybe a pic!
Michigan Rick
Michigan Rick
#34
#35
Rick from Michigan
#36
Yes. The late 289 style water pump is built like the later, 302 style, like your '80 pump, but the shape and length is different. But the bolt pattern is the same, and will fit on your later cover. Ford changed the water pumps, brackets, pullies, etc., on the small blocks to the "newer" style in 1970, but left the timing covers the same.
BTW, that "soft plug" you mentioned on your early cover, that's where the oil filler spout used to be, before they had a hole in the valve cover for it, pre '64.
#37
Does the 66/69 waterpump have the sheetmetal back? Cause the 1980 does and the 289 style doesn't. Seep hole in bottom of 302 timing chain cover for whatever that may seep out between sheetmetal backing plate on 302 pump and not in 289 cover. The 289 cover is fully enclosed since the back is open on the 289 waterpump and would leak otherwise.
Rick from Michigan
Rick from Michigan
#38
It's alive
Thanks again guys for all the help and confusion.....some supplied by me!
Since it was so cold like most winters I decided to not start my new motor till it got warmer......I finally started it this past weekend. I haven't drove it yet but it purrs like a cat! So in a day or 2 I'll see if it runs as good as it sounds. Maybe Wednesday I'll go for a 50 miler shake down.
Wish me luck...........Michigan Rick
BigRobK
19
12-09-2015 05:44 AM
GreatNorthWoods
27
04-25-2011 12:53 PM
GreatNorthWoods
04-30-2010 06:25 AM
