Im currently building a 56 f100 and plan on using a 460 BB and C-6 trans but looking at the transmission it has a few wires im not sure where they go so if anyone could point me in the right directionto finding a diagram that would be awesome, Thanks
I may have the same issue as Nordvik. Is there a diagram which shows which wire is the neutral safety switch and which is the reverse lights? I know I could connect everything and use a tester but, having a color code or diagram would be very helpful in building the harness before I install the engine and trans.
