Automatic or Manual Transmission Fluid?
Old 09-24-2009, 01:23 AM
nextalcupfan's Avatar
nextalcupfan
nextalcupfan is offline
Im getting ready to do a full tuneup on my 1995 f-150 5-speed 2WD.
Ive been trying to find out what type of fluid my tranny uses but i cant seem to get a clear answer, ive read that if its a mazda 5-speed it uses auto tranny fluid and if its a zf-5 it uses standard manual tranny fluid.
i dont know which i have because the truck has had a engine swap (supposidly with a mustang) so it might have a different tranny.
all i can tell u is the tranny is ribbed all over (like cooling fins)
any help would be apreciated
Old 09-24-2009, 02:22 AM
phoneman91's Avatar
phoneman91
phoneman91 is offline
My 92 F Series Ford Shop Manual states that both manual transmission use Mercon automatic transmission fluid. Your F150 should have the Mazda M5R2 five speed manual transmission installed at the factory.
Old 09-24-2009, 04:38 AM
BigSix1's Avatar
BigSix1
BigSix1 is offline
If you suspect a trans swap you should post a pic of your tranny--someone will identify it in short order, and you can go from there.
Just my .02.
Old 09-24-2009, 07:29 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
If it is an aluminum case trans, it uses ATF.(or you can use GM's SYNCROMESH,Realy good stuff but not cheap)f it is a cast iron trans, it uses Gear oil.
Old 09-24-2009, 07:59 AM
nextalcupfan
its definatly looks like dull aluminum, ill take a pic later tonight
Old 09-24-2009, 01:21 PM
nstueve's Avatar
nstueve
nstueve is offline
The first is the mazda and the second is the ZF. Either way I put Mobil 1 Synthetic ATF in my ZF-542 and haven't had a problem in the last 2-3 years. Mobile 1 is supposed to be the best/most affordable synthetic you can buy. I run full synthetic in my vehicles for the last 5 years and change at 10,000!!! You can usually get it at wal-mart or your local auto parts store. Also my buddy used to work for Ford and was their tranny mechanic... he informed me after the fact that you can get the ford brand synthetic just as cheap at the dealership and it pretty good stuff to from what he says. I'd just recommend a synthetic ATF...
Old 09-24-2009, 05:32 PM
nextalcupfan
ya its definatly the mazda
anyone know what the capacity is?
Old 09-25-2009, 08:25 AM
nstueve's Avatar
nstueve
nstueve is offline
3.7 or 3.8 qts I believe... Either way you'll need to buy 4qts to top it off...
Old 09-25-2009, 02:08 PM
Ricache's Avatar
Ricache
Ricache is offline
Definitely a Mercon compatible ATF for that Tranny. You'll need to buy 4 Qts but it only takes 3.7 or 3.8 like NSTUEVE said.
I did mine last month - same tranny.
Pretty easy and relatively quick job if the drain and fill plugs cooperate.
/Ricache
Old 04-10-2013, 08:48 PM
cengen903's Avatar
cengen903
cengen903 is offline
Dexron III / Mercon ATF
Will Dexron III / Mercon ATF Work in the Mazda M5R2 Manual Transmission??? if so also i have a borg/werner Transfer Case Hooked to the back of the tranny and was wondering what it takes for fluid and the cap.... i havnt changed either in about 3 years and am wanting to... also the reason i am asking if this atf will work is cause i have a bour 6 qts kicking around and have no other vecheil that it is compatiabale with.... please dont tell me it will if it will hurt it... i have no exta $$$ to repair it... i just did the slave and i hated it but i had no chooice...
thanks in advanced
Old 04-11-2013, 08:55 AM
jas88's Avatar
jas88
jas88 is offline
You can use any ATF in a manual trans that calls for ATF. It is not important for it to be Mercon III or V or Dexron or whatever. You could even use Type F, if you could find any.
dreamofford
06-03-2017 12:35 PM
zbs60
22
03-02-2017 08:35 PM
pawpaw
1983 - 2012 Ranger & B-Series
17
04-26-2014 08:52 PM
Flame Out
Oil & Lubrication
23
08-09-2010 10:28 AM
frankenbroncoII
11-23-2007 03:48 AM
Quick Reply: Automatic or Manual Transmission Fluid?
