Bed Rail Caps
Old 09-23-2009, 12:50 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
Bed Rail Caps
So i got a great deal on a set of bed rails.....and need to put them on. My lariat of course has no stake pocket cut outs....so i need to take the bed caps off and cut them out.....anyone know how the bed rail caps come off???
Old 09-23-2009, 01:44 PM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
well if your talking about the factory plastic caps have fun
youll need plyers and a long interior tool
get inside the bed, best to start up by the cap, look under the bed rail youll see plastic clips, use the plyes to squeeze clip and push up on them
now that only works on some of them and thats were the interior tool come in to play to pry the clips out
be carefull it doesn't take much to break the clips....i've never taken on off with out breaking one clip
Old 09-23-2009, 07:56 PM
Ryan50hrl's Avatar
Ryan50hrl
are the clips replaceable???? or if i break it am i sol?
Old 09-23-2009, 08:02 PM
silver05fx4
nope, you'll have to buy a new cap
but their not really pricey tho
i'm guessing you have a 5.5 bed ...i would look to find the hole and use a hole saw
Old 09-23-2009, 08:35 PM
Helix360's Avatar
Helix360
Helix360 is offline
glad you received your bed rails...
as far as the bed caps go, if you try to take them off with out breaking any clips,make sure you try this on a warm day whe the plastic is nice and warm. start from the tail gate and work towards the cab. take your time. when i took them off mine to replace them it was cold and only broke one clip.
they are not to expensive to replace i paid around $55.00 for the pair with my dealer discount. i would expect you would pay around $75.00 without a discount.
good luck!
Old 09-23-2009, 09:35 PM
stronger's Avatar
stronger
stronger is offline
I think I gave either 45 or 65 for a 6.5' one two years ago. Mine was scratched so I replaced it and tried to learn how to do it without snapping the molded plastic clip. I did it on a warm day, in direct sunlight And I kept my hot water hose handy. yes, I got wet but I ran water down the top, worked a few up, more water, got a few more. a shot of wd-4o or the like helps A Lot. after you get it started, spray the underside so that it drips down toward the next clips. I think there were about 12 clips in 6.5'. rear bumper step pads come off the same way.
Old 09-24-2009, 09:16 AM
Ryan50hrl's Avatar
Ryan50hrl
1st off.....a big shout out to helix360....thanks a bunch for the rails....
2nd....maybe i'll just cut them out from the top...i guess i'll have no real reason to ever take the rails off so you'll never see the cut out anyhow....
Old 09-24-2009, 10:11 AM
Gearbanger 101's Avatar
Gearbanger 101
Gearbanger 101 is offline
I hear all this talk about the Lincoln bed rails. What's so special about them? Anyone have a pic of a set on their truck vs the stock F150 rails? Just wanna know what all the hype is about?
Old 09-24-2009, 05:16 PM
Ryan50hrl's Avatar
Ryan50hrl
http://image7.autorevo.com/642/pics/...910a46882c.jpg
The chrome rails on the bed.....weren't available on fords.....and in my opinion...look much classier than the aftermarket options
Old 09-25-2009, 07:02 AM
Gearbanger 101
I gotcha....not my taste considering I bought my FX4 to eliminate the chrome, but I can see how they might be apealing to someone with a Lariat or the like, with an abundance of it on their vehicle.
Old 09-26-2009, 06:26 PM
spatts's Avatar
spatts
spatts is offline
I can tell you if your working on a SuperCrew then you have no stake posts just a rectangular cut out and thats it !!!!!!
reamer
09-13-2015 09:09 PM
Pastortom1
17
03-19-2012 11:17 PM
Storm
1999 to 2016 Super Duty
10-03-2007 12:08 PM
uncleBS
03-07-2002 05:54 AM
Quick Reply: Bed Rail Caps
