95 F-150 ongoing weird starting problems - Ford Truck Enthusiasts Forums
Old 09-23-2009, 11:39 AM
dan1101's Avatar
dan1101 dan1101 is offline
dan1101 is starting off with a positive reputation.
I have a 95 F-150 that occasionaly doesn't like to start. When you turn the key it will just click once. I have replaced the battery, battery cable ends, starter, and starter solenoid with no luck. Problem got better after replacing the starter with a NAPA one but then returned months later. I can always get the truck to start by moving the key from ACC to Start several times in a row.
More recently it has started a thing where it cranks strongly but won't start. Usually after 5 or 10 tries it will start. I do hear the fuel pump run when I turn the key. The weird thing is this problem never happens at the same time as the "click" problem.
Yesterday it cranked and cranked but wouldn't start. I disconnected the negative battery cable and connected it back up, then got the clicking problem, after a few clicking tries it cranked and started right up.
I can't help but think I've got an electrical problem of some sort. Once the truck starts it runs strong and hasn't ever quit on me on the road (yet.) What sort of electrical issue could result in the "click" when trying to start and the condition of it cranking but not firing up?
I did pull codes and got a code 121, which means closed throttle voltage higher or lower than expected. If there's a TPS problem I could see how this could maybe figure into the no firing up problem, but not the clicking problem.
Old 09-23-2009, 12:13 PM
skaterbro's Avatar
skaterbro skaterbro is offline
skaterbro is starting off with a positive reputation.
Replace your grounds. Replacing just the ends doesn't really rule out grounding issues. I did my ground in two pieces, both 2 gauge.
Go from there.
Old 09-23-2009, 01:21 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
I take it your lights stay on during the click from the starter relay.
If so you may need to cut the spade terminal off the small red wire going to the starter Solenoid from the starter relay and crimp a new on one. This happens a lot with this spade causing the one click.
Make sure your ground cable from the NEG post of the battery goes to the block and not just the frame. The frame is not a ground for the truck, it is just used if you pull a trailer.
The cranking and not starting is unrelated to the click and requires you to find out if you have spark, the injectors are firing, you have fuel pressure, a good body and computer grounds.
Old 09-24-2009, 01:44 PM
dan1101's Avatar
Yeah, I've thought in the past that I might need to do replace the grounds. I thought it would be more complicated than that.
My new NAPA starter doesn't have the spade terminal, they actually improved on Ford's design on that one.
The NEG terminal is normally grounded to the frame on a stock truck isn't it? So I should find a bolt on the engine block to attach it to?
Old 09-24-2009, 02:51 PM
skaterbro's Avatar
The one piece ground cable, from factory, goes from the neg battery terminal to the frame then to the block. What you want to do is run a long cable from the battery straight to the block, and a short one from the block to the frame. The two cables i showed are 48" and 19" long.
The only tough part of this job is getting to the block bolt. I'll find some pics of both the block and frame grounding point and post em up.
Old 09-24-2009, 03:03 PM
subford's Avatar
Unless you are pulling trailers you do not have to run a ground to the frame, just the block.
The frame ground is just for the white wire on the trailer plug. It is also used for the ground for the license plate light if you do not have a back bumper.
Old 09-24-2009, 04:30 PM
gearhead351 gearhead351 is offline
gearhead351 is starting off with a positive reputation.
just wondering, have you check the ignition switch? This sounds like a similar problem I had.
Old 09-24-2009, 05:01 PM
skaterbro's Avatar
Quote:
Good bit of info i did not know. Thank you sir.
Old 09-24-2009, 05:35 PM
subford's Avatar
Maybe I should add you also need a good ground from the NEG post to the Body.
Old 09-24-2009, 06:18 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
I had a very similar problem when I first bought my truck and the problem turned out to be the ground on the passenger fender between the starter relay and the battery. Took me three days, but cleaning up that ground solved the problem.
Old 09-28-2009, 12:48 PM
dan1101's Avatar
Thanks for the advice, I think I'm gonna just start going through connections and cleaning them, I'm sure after 15 years there are quite a few dirty connections. Will also replace the grounds.
My "cranking but not starting" problem still persists. I've found that when I turn the key to Acc, I can hear the fuel pump run for a second. But when it doesn't start, if I keep turning the key Off then to Acc eventually the pump runs for a sec, then pauses, then runs again. Once it does that the truck starts fine. I'm thinking maybe fuel pump relay or fuel filter?
Old 09-28-2009, 02:06 PM
subford's Avatar
Could also be the Ignition Switch.
The fuel pump should not run in the ACC position.
Old 09-29-2009, 12:36 PM
dan1101's Avatar
I guess maybe it's not Acc. I should be hearing the fuel pump run when I turn the key to the position just before Start, right?
Old 09-29-2009, 01:39 PM
subford's Avatar
Yes you should hear it in the on position.
Old 09-29-2009, 02:42 PM
dan1101's Avatar
What about the pump running, then pausing, then running again? It won't do it every time, but when it does, it starts fine.
Strange electrical puzzle RickardC Electrical Systems/Wiring 7 10-05-2014 08:37 PM
Strange electrical problem RickardC 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 09-20-2014 04:41 PM
Electrical problem almeras 1987 - 1996 F150 & Larger F-Series Trucks 3 01-31-2010 10:04 PM
Starting Problems with 351w on '82 F250 lvbakers5 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-09-2004 12:50 PM
79 f150 won't start, solenoid / relay problem? ToolDude 1973 - 1979 F-100 & Larger F-Series Trucks 17 04-22-2004 03:37 AM
Tags
51, 95, cable, code, f150, ford, gauge, ground, ignition, problems, starter, starting, truck, trucks, weird, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
