Proper oil for 360/390 - Ford Truck Enthusiasts Forums
Old 09-23-2009, 03:04 AM
Brock_Samson Brock_Samson is offline
Brock_Samson is starting off with a positive reputation.
Question Proper oil for 360/390
Im new to the FE block, what Oil Should I be running?
I have a '68 F250 w/ 360 FE
Im hearing all kinds of things 10w/40, 20w/50, 30w
What is best?
Old 09-23-2009, 06:34 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Brock, When the FE was designed in the 50s there was only 30 wt. oil for the most part. Then we got HD multi wt. 10W40 etc. The newer engines were designed to run 5W30 and thinner oils to get the mpgs up.
You can spend all the money that you pockets will hold on the new style oils, I see some $7-8.00 a qt.
I am convinced that regular changing is more important than using high dollar oils. Any good 10W30 oil with new filter will get you 200,000 miles or more. There aren't many folk that will put that many miles on an engine. I have well over a million miles on engines under my care since my wife and I have been driving, and no failure due to oil.
Your 68 prolly has been running 10W40 and since that is harder to come by these days, 10W30 is a good choice.
I'm sure others will offer their opinions shortly.
John
Old 09-23-2009, 09:12 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
It depends on the condition of your engine. How's the oil pressure at idle when it's hot?
Generally, 10W40 is a good start, but if you have oil pressure issues at idle, a 20W50 might be better.
Old 09-23-2009, 03:25 PM
Thumbs up
I'm not that deep yet, all but the gass guage & speedo are broke. and im still working on the Carb & Spark. compression is good, 126k mi.
after i get her running temp/oil pressure cluster should be on my list.
My dad did a fresh Oil/Filter with 30w b4 he handed her down to me.
I think I'm going to stick with that for now.
Old 09-24-2009, 11:24 AM
yellow truck's Avatar
yellow truck yellow truck is offline
yellow truck is gaining momentum as a positive member of FTE.
I run 15W40 based on some advice received from a couple of friends who build old FE engines. Mine has great oil pressure, but the advice was based on the fact that 15W40 is essentially diesel engine oil and it has all the nasty additives that are missing from most car oils these days.
They claim that the factory shipped the 390 interceptors and 428 SCJ engines with 20W50.
Old 09-24-2009, 10:20 PM
410 Highboy's Avatar
410 Highboy 410 Highboy is offline
410 Highboy is starting off with a positive reputation.
Comp Cams recommends breakin with Shell Rotella oil . It has a higher zinc content whitch is more compatable with flat tappit cams .You can run an additive like ZDDP to replace the additives .Motorcycle specific oils have a high zinc content also . I have heard a lot of negetive coments about 10-40 .I have been told more than once that the mix doesn't lubricate well . I use 20-50 in my 78 Airhead BMW and 10-30 in my 410 FE. I reciently bought several quarts of Valvoline Durablend ( It's just now broken in and oil changes take 9 1/4 quarts , so I look for oil at a discount ) .Keeping the oil and filter fresh ( almost no matter what oil you use ) is going to add to the longevity of your engine .
Old 09-25-2009, 11:24 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
My ol 352 got 10w40 and that was with 150K miles on it. Ran fine. Only with a fresh rebuild would I be concerned with zinc and the additives. The old stuff is more then broke in and will survive with just about anything.
Old 09-25-2009, 11:36 AM
crescentwrencher crescentwrencher is offline
crescentwrencher is starting off with a positive reputation.
[quote=yellow truck;7965768]I run 15W40 based on some advice received from a couple of friends who build old FE engines. Mine has great oil pressure, but the advice was based on the fact that 15W40 is essentially diesel engine oil and it has all the nasty additives that are missing from most car oils these days.
quote]
exactly what i do
Old 10-02-2009, 05:01 PM
CrazyAirman's Avatar
CrazyAirman CrazyAirman is offline
CrazyAirman is gaining momentum as a positive member of FTE.
I run 10w40 in summer, and 10w30 in winter in my 390. On a hot day, I never see pressure below 20 @ idle.
Old 10-04-2009, 02:30 PM
Lightbulb
This will work good for me, i use delo 15-40 for my '99 7.3L F350. it makes it easy if both my trucks run the same oil. they sell 15-40 Delo by the case At costco. i have also been thinking of switching from delo to Motorcraft, they have it @ autozone in the 5 qt. container for 10 bux.
Rotella is a good oil but its spendy, i have a buddy with a CTD thats all he will run.
Old 10-05-2009, 05:40 PM
ulysses69 ulysses69 is offline
ulysses69 is starting off with a positive reputation.
the 390 is a tuff engine has a poor oiling system on a new rebuild run shell rotella-t for break in. I run a good quality 30 w
Old 10-07-2009, 11:12 PM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
Old 10-08-2009, 02:59 AM
any body looking for some 390 parts? I got a toploader 4speed with lakewood bellhousing id tag rug-j. 1wire alternator 100 amp, headers adjustible rockers matching number heads and intake. I am doing the 4.6 convert on my 68 f100 need to make space.
Old 10-08-2009, 10:58 PM
Kennewick's Avatar
Quote:
Nice high jack!!!
Old 10-09-2009, 07:53 AM
Kalve's Avatar
Kalve Kalve is offline
Kalve is starting off with a positive reputation.
Does it matter what brand of oil to use is one better than the other? An should I run Synthetic oil?
Ford 360 FE davelong667 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 27 12-16-2016 02:08 PM
what oil to use in FE 360 Cenzo777 Oil & Lubrication 17 02-26-2016 09:28 PM
351w or 302? 67shorty352 1967 - 1972 F-100 & Larger F-Series Trucks 19 03-26-2015 04:14 PM
FE 360 advantage to 351W raven3 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 30 07-03-2014 08:27 PM
what motor will move a 68 f250 the best 94z28 1967 - 1972 F-100 & Larger F-Series Trucks 14 02-29-2012 07:31 PM
Tags
10, 352, 360, 360ford, 390, 40, 428, engine, fe, ford, oil, qts, truck, v8, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
