97 F150 4x4 4.6 sputtering, runs rough - Ford Truck Enthusiasts Forums
Old 09-23-2009, 12:48 AM
m90mustang m90mustang is offline
m90mustang is starting off with a positive reputation.
I recently purchased a 97 f150 4r70w 4x4 with a 4.6L and am having trouble pinpointing a problem. It at first was gutless and found that the bank 2 cat was melted and replaced that and now has a little more power. Now i'm trying to find what is causing a misfire feeling when driving. This also happens when reving in park/neutral. It will hesitate and then rpms will go up. When driving it is not there until it warms up and at any speed you give it a little gas to accelerate and the feeling gets worse. When you put the pedal all the way down it hesitates and then the rpms shoot up but there is no power there and you slowly start to speed up. This happens in both overdrive and overdrive off at all speeds. Please help, i'm stumped
Old 09-23-2009, 05:53 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
I'd start by getting the codes read. Even if the light isn't on, there might be something stored. You can try cleaning the MAF with electric contact cleaner. Plugs and wires (Motorcraft) is also something else you can do that may solve the problem.
Old 09-23-2009, 09:29 AM
Alright, i'll give that a shot first. I'll let you know if it fixes it.
Old 09-23-2009, 08:48 PM
Thudpucker's Avatar
Thudpucker Thudpucker is offline
Thudpucker is gaining momentum as a positive member of FTE.
I'm betting a bad plug wire. #4 OMG . I just had the same symptoms.
Old 09-23-2009, 11:42 PM
Well, i'm pretty much carpet bombing the whole ignition. I ordered up some motorcraft coilpacks, spark plugs, and spark plug wires. Hopefully this fixes it.
Old 09-24-2009, 06:21 AM
Joe Finn's Avatar
Good luck! How many miles on her?
Old 09-24-2009, 09:30 AM
221,000 and it recently put an engine in with less miles at around 120,000 lol.
Old 09-27-2009, 04:00 AM
Well, now she runs great! I replaced everything since it was really high mileage, but in the end it was the plug wires that were causing the problem. Tested all of the plug wires with my multimeter and did a resistance test and 3 of them ended up having an open somewhere in the wires.
hesitation/fuel pedal issue? 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 5 07-25-2016 07:23 PM
Acceleration/ power problem new transmission Josh726 1997 - 2003 F150 13 12-04-2015 08:56 PM
P0452 code, erratic idle & gear shifting 97flairside 1997 - 2003 F150 4 11-27-2010 12:53 PM
2003 F150 Shudders/Hesitates in Overdrive Tritonic 1997 - 2003 F150 3 04-26-2010 11:03 AM
Sucking Hesitation debestuss Modular V8 (4.6L, 5.4L) 3 03-18-2009 03:04 PM
Tags
46l, 4x4, 97, 99, accelerating, f150, ford, hesitation, m90mustang, rough, run, runs, sputtering, truck, warms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
