Engine compartment light switch - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-22-2009, 07:45 PM
madmax55555 madmax55555 is offline
madmax55555 is starting off with a positive reputation.
Mine's missing....wiring is there but no switch.
Looked at the wreckers, but all of them there had different size socket. Even from the same year...my socket is wider than the others I saw so it won't plug in.
My truck is a 2005 F350 SD .
Part number on the switch that DOESN'T fit is YW1A-15702-BA.
Does anyone out there have a similar truck with a different numbered switch, or are there any Ford parts guys here that can look it up and see if there are 2 different switches for the same year? I think it would be odd if there were....
Parking brake switch part # / dash light on jpankask Excursion - King of SUVs 1 10-29-2016 05:03 PM
Headlight Sockets Chevmn56 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-20-2014 07:34 AM
Turn signal switch thunderbirdcakes 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-24-2012 01:26 PM
HOWTO - HOW TO CONVERT YOUR FACTORY LIGHTER SOCKET TO BE KEY-SWITCHED TheKirbyMan '80-'86 HOWTO's 0 12-01-2010 02:34 AM
Paging Numberdummy.. and a question too.. Nathan Plemons 1973 - 1979 F-100 & Larger F-Series Trucks 26 11-19-2010 01:09 PM
Tags
ford, yw1a15702ba
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
