Starter bolts - Ford Truck Enthusiasts Forums
Starter bolts
Old 09-22-2009, 03:39 PM
61 uni's Avatar
61 uni 61 uni is offline
61 uni is gaining momentum as a positive member of FTE.
Starter bolts
I checked today and sure enough I'm missing one. Does the end of the bolt have to be turned down like the oem bolt? Is blue locktite good enough?
Old 09-22-2009, 08:05 PM
89LX306 89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
You might want to check and make sure the bolt hole is not stripped. Mine was.
Old 09-22-2009, 08:25 PM
61 uni's Avatar
Quote:
I'm gonna chase the threads with a tap before I put it in.
Old 09-22-2009, 10:37 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
I had problems with my starter bolt backing out. So far the helicoil has worked great. No problems or backing out. What starter are you using?
Old 09-23-2009, 08:17 AM
61 uni's Avatar
Quote:
As far as I know it's stock. It grinded pretty bad monday and sure enough a bolt was missing. The threads has a lot of trash in it, so i'm guessing it's been gone for a while.
Old 09-23-2009, 08:21 AM
FWIW mine has backed out 3 times in 200k miles. I have cleaned them and used loctite each time.
Old 09-23-2009, 08:22 AM
61 uni's Avatar
red or blue
Old 09-23-2009, 09:16 AM
Blue the first time, red this last time. Of course my threads my have given up when I snugged the bolt down the last time.
Old 09-23-2009, 10:36 AM
dcf4x4's Avatar
dcf4x4 dcf4x4 is offline
dcf4x4 has a good reputation on FTE.dcf4x4 has a good reputation on FTE.
Is this all random occurrence?
I almost lost mine as well, a month ago. Upper bolt was missing, and had been for awhile, and the lower was half way out. The first time in 5 years and 2 starters. I changed the starter exactly a year ago.
Just wondering what would have caused this. I red locktighted the bolts and so far so good.
Old 09-23-2009, 07:10 PM
duck fan's Avatar
duck fan duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Its interesting, and it may just be coincidence, but all of you have 2002 trucks with the exception of dcf4x4 who has a 2000. However, he has replaced his starter and since locktite has been good to go.
Old 09-23-2009, 08:32 PM
RedBoat's Avatar
RedBoat RedBoat is offline
Rather Be Floatin
RedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to beholdRedBoat is a splendid one to behold
Mines an 03, I guess I need to get under there and make sure they are snug.
2 bolt or 4 bolt block? seajr1978 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-06-2012 06:47 PM
Is 20 foot pounds really enough Cowman79 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-31-2011 09:45 AM
Torque value for driveshaft bolts 67nukeford 1997 - 2003 F150 2 10-23-2008 07:40 AM
Bolts, Bolts, & more Bolts parks911 Paint & Bodywork 21 04-08-2004 11:30 PM
Top mounting hardware AbadDriver 1978 - 1996 Big Bronco 10 07-08-2003 09:11 AM
Tags
2000, 73l, bolt, f350, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
