Weight of my truck
Old 09-22-2009, 11:21 AM
johnsf's Avatar
johnsf
johnsf is offline
Weight of my truck
I have a 1956 f100 with a ford 460 engine, it has aluminum heads and also a C6 trans. I'm wondering what it might weigh,I have no way of weighing so I'm looking for an approximate weight.
John F.
Old 09-22-2009, 11:39 AM
Dr G's Avatar
Dr G
Dr G is offline
John F.
That pretty much describes the truck I just bought. I have to get it weighed in order to get it registered here in CA (truck is from SD). If no one else has the answer, I'll probably get to the scales in the next week or two.
Gustave
Old 09-22-2009, 12:00 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
a close guess as I haven't done a specific weighing
my trailer loaded, 3 spares (2 mounted), 4 chairs, canopy, battery and some stuff, weighed 6590. trailer is supposed to be around 3000lbs. so my guess is the truck is 3000-3200lbs with the 460/c6 combo.
Sam
Old 09-22-2009, 12:06 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Hi John,
Is your truck running? If it is you can go to the local land fill and they will give you a weight ticket for it. It may cost $5. Or if you have a local truck stop they may have a scale as well.
If it's not running, maybe one of the folks with a Salesmans Handbook for that year can give you the curb weight. With Aluminum heads and (I'm assuming intake manifold as well) your 460 will weigh about the same as a Y-block. Stock there is about 100 pounds difference. The C6 weighs about 200 pounds (with fluid), so your weight will be around 100-150 pounds more than the stock curb weight.
If you assume a curb weight for a stock 56 F-100 with the 6 cylinder engine to be 3070 lbs, or 3240 lbs with the Y-block, I would venture to say your truck weighs somewhere in the neighborhood of 3350-3400 pounds.
Here is a link to another thread that has F-100 Curb weights (post #3).
https://www.ford-trucks.com/forums/1...f100-f250.html
Old 09-22-2009, 01:37 PM
husker's Avatar
husker
husker is offline
I have a 54 F250 with a 460/C6 and a 72 F250 rear axle. The engine and tranny are stock. The truck weighs in at around 3900# at the land fill when empty. That should give you a ball park.
I'll concur with others that it would weigh in at 3200-3500 lbs.
Old 09-22-2009, 08:51 PM
eman92082's Avatar
eman92082
eman92082 is offline
Gustave
Weighed mine in Simi Valley at the trash / recycling center. Cost about $15 bones as I recall.
Old 09-23-2009, 11:12 AM
Dr G's Avatar
Dr G
Dr G is offline
Thanks for the tip. The DMW paperwork says I have to get it weighed at a "Certified California Weighmaster". The only one I've found is in Sun Valley. Did you use your weight slip for DMV purposes?
Gustave
Old 09-23-2009, 12:02 PM
Julies Cool F1
The county run scales at the dumps and recycling centers are Ca. Certified. I got mine weighed at EDCO. They have garbage transfere stations all over the place. They give you a little card - about the size of a business card and a paper reciept - I think mine was $5.
Your landfill scales up there are all Ca. Certified.
Old 09-23-2009, 01:25 PM
Dr G's Avatar
Dr G
Dr G is offline
Sorry if this is a threadjack.
I scratched around a bit on the web and managed to find a list of certified scales in CA. There is one in Van Nuys just a couple miles a way, so that will work best.
Thanks,
Gustave
Old 09-23-2009, 08:02 PM
eman92082's Avatar
eman92082
Gustave
For the record - Yes. I drove directly from the weigh to the Simi DMV
Good Luck
Old 01-09-2010, 02:55 PM
Dr G's Avatar
Dr G
Dr G is offline
I'm resurecting this thread. I got my trucked weighed today and wanted to post the weight for future reference for others. 3520lbs with 460 and C6. Straight axle. Iron heads, intake and exhaust manifolds.
Gustave
Old 01-09-2010, 06:42 PM
husker's Avatar
husker
husker is offline
My 54 F250 with the same engine, but with a dana 60 in back, heavy springs, and long bed weighs about 400 pounds more.
Old 01-10-2010, 02:00 AM
Julies Cool F1
Aha! See you fibbed to us on your original post - you said you had aluminum heads! So the 120 Lbs I was under would have been almost exact with aluminum heads.
Were you in the truck when they weighed it? (there's another 200#).
Also, not to be overly critical, but you may want to be careful publishing tickets like this one that show your address and the type of truck you have. Our posts here can be pulled in google searches by anyone - including pictures of you or your truck if you post them. I'd hate to see you get ripped off!!!!!
Old 01-10-2010, 10:18 AM
Dr G's Avatar
Dr G
Dr G is offline
Good point, though I said I had "pretty much" the same truck, mainly referring to the 460. At that point I was looking for something close to tell the DMV. I was not in the truck when it was weighed, (I weigh 195 lbs ). Not worried about the VIN number at all, but thanks for your concern.
Gustave
Old 01-10-2010, 11:32 AM
Julies Cool F1
Tee hee - 195 even after the Holidays? Just teasing!
I thought we were having a contest. I was looking forward to my "Cupie Doll."
Oh well. Glad youfinally got it weighed and hopefully the DMV will be decent. They seem to be on the rampage lately.
If you have AAA I'd go there instead. If you don't have AAA it might be worth your time saved to join for $47!!!! They have really helped me over the years.
93-331-29PSI
6.7L Power Stroke Diesel
12-10-2015 12:04 PM
Biggziff
1999 to 2016 Super Duty
19
06-17-2015 05:20 AM
Ordnance
09-08-2014 08:59 PM
skidooman
Fifth Wheel & Gooseneck RV Towing
26
01-09-2014 08:31 PM
fulltimehiboy
06-21-2013 04:30 AM
Quick Reply: Weight of my truck
