84 E-350 Fuel Pumps
84 E-350 Fuel Pumps
Hi all, I hope I put this in the right forum...
I have a 84 E-350 MotorHome With a 460, Holly 4 barrel. I have the in tank fuel pumps and no other fuel pumps. I've been doing some reading on this fuel delivery system and to tell you the truth, I don't like it...LOL (Only pump while engine cranking, and if it has oil pressure) I'm a Ford fan, but don't understand what they were thinking...
My problem is and I know it is wierd, both my fuel pumps are shot... I put power to both and nothing... I even took them out and put power to the pump on it's connectors and still nothing... I know these aren't cheap and I really don't have the money to put $200 in to fuel pumps...
Is this possible...
Can I get an after market 4-7 psi pump and mount it on the frame rail in front of the tank selector?
Or can I put a manual pump on the 460, is there a lobe for the pump to run?
If this will work, since I have the pump out I will replace the "internal hose above the pump so it wouldn't suck air...
I have a 88 F-150 junked out with the 2 intank pumps and the other pump on the frame rail. but after doing part number searching, I see the intank pumps are different... And I would think the frame pump would most likely not suck the fuel and probably put out too much psi being out of a fuel injection system. Correct?
Any Ideas of a good, cheap fix?
Thanks you all for your time and help!!!
Is this possible...
dgeist
60
02-15-2014 09:50 AM
Jordanz_03
03-12-2012 02:27 PM
91chevywt
02-04-2011 10:10 AM
