H2E VS 38R + Hybrids
#46
#47
I am glad I got my 38r shipped for $1090 to the door no brainier for me. Thanks Mike (BPP).Also I know a few thats running over 500hp with the 38r but if you want to go higher yes go with the H2E Mod or better + supporting mods. How much do you want to spend is the ? plus as stated look at the pressures. You don't want blow.
#48
I have not heard that the 38R has a snappier response because I have that one. It does lag a bit with the 1.15 housing in mine in the lower tunes but anything over the 100 setting forget lag. My drive pressure is not a problem with the housing. I have not seen the surge. I do hear the whine.
There are some good prices being quoted for a new 38R here.
I suppose I could dig up the turbo maps, again.
#49
#50
#51
Well Unfortunately since I ran out of my subscriber status, and am currently in financial binds preventing me from becoming a supporter again right now, I cannot attach the two maps that I have of both turbos(GTP38R + H2E) that clearly show that the H2E outflows the GTP38R. I didn't realize that this was a question. . . but the H2E is a larger more capable turbo. If you want my opinion. . . the H2E or a similarly sized turbo is a better choice for 400+ applications. Its stable, not working too hard, just a damn good setup in my opinion. Anything larger in HP range requiring larger than and H2E in my opinion needs compounds to be a nice streetable setup without crazy amounts of lag and smoke. This is my opinion having run compounds. and currently running a fairly high HP H2E.
Timmy
Timmy
#52
Timmy
Timmy
#53
OK, here we go:
H2E 400-500HP calculation plot:
The stock GTP38R from 400-500 (stock housing):
This is using old school calculation math from the Garret turbo 101-103 section off of their site for a 7.3. Feel free to wear you brain out and recalculate it.
I don't pretend to interpret data but look at what ratio things happen for 400hp. That is where I began looking. It seems obvious the H2E has a much greater top end. I have a not stock 1.15 housing GTP38R and have no map for that as well as a modded H2E map. I generally run a confirmed 1 to 1 drive ratio when on the turbo with my setup. Very safe and low EGTs. That also involves tuning along with physical characteristics. It also seems clear that the H2E has a higher HP potential just looking at the maps and my calculations.
As for real world, that is where things happen.
#54
OK, here we go:
Anyone want to PM me some info on how to read this map.. Andy simple boy...
Thanks guys.. how bout a 42R or GT45 vs. a H2E
#55
Go to the Garrett site and read. It starts simple and then gets hard. I have not seen maps for the first turbos you speak of but have not looked. A real clever person could figure it out from the housing, impellar and compressor size. Bet there are not that many clever folks here, including myself.
#56
I have a modded H2e with standard hybrids and now 100% over nozzles. There is 0 lag issues with this turbo and hybrids. at 48#'s boost I am sitting right at 50-55#'s drive pressure. I also have a 19cm housing to try at some point, but I need to get her back on the road first.
If I had it to do over, I would not have spent one dime on a drop in turbo. Not a modded stocker, TN, or 38r... H2e or other is the only way to go.
#57
#58
What is the HP limit on that turbo? I am turbo shopping at the moment and I wanna hit 500-525HP.
Thanks
