Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-17-2009, 07:38 AM
tjc transport's Avatar
tjc transport tjc transport is online now
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
there is no need to put an additive in the fuel, unless you have water in the tank.
my truck is 22 years old and has never had anything added to the fuel except for what the refinery's put in it, and i have never had any problems with any of my trucks. some of the trucks i sold to the regular drivers now have over 400,000 miles on them and are still going strong.
with the exception of new injector pumps every 150k miles, glow plugs, and vacuum pumps, those trucks are still all stock too.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #17 (permalink)
Old 10-17-2009, 02:24 PM
Kenworth Kenworth is offline
Kenworth is starting off with a positive reputation.
You have to use fuel additive now the ultra low sulphur fuel will wipe out a mechanical injection pump in no time. The old Stanadyne pumps were designed for diesel that had lubrication.
  #18 (permalink)
Old 10-17-2009, 06:29 PM
oh no, not again!!
Quote:
totally false.
when sulfur was removed from diesel fuel, a lubricant was automatically added to the fuel at the refinery to replace the lubricities lost by removing the sulfur.
as i said before, i have never added anything of any kind to my fuel, and have never had any problems.
the injector pump in my 88 has 120,000 miles on it so far running strictly ULSDF
__________________
Tom
  #19 (permalink)
Old 10-19-2009, 06:19 PM
Chief10Beers Chief10Beers is offline
Chief10Beers is starting off with a positive reputation.
a good fix for the sluggish power would be an after market turbo. my 93 IDI has a banks turbo on it and i out run 6.0 and 6.4 PSD's all the time
  #20 (permalink)
Old 10-19-2009, 07:26 PM
jsimon724's Avatar
jsimon724 jsimon724 is offline
jsimon724 is starting off with a positive reputation.
Quote:
Ok, I gotta throw the BS flag on this one. Unless you've done a whole lot more to it that you're not telling us, you ain't outrunning 6.0 & 6.4 PSDs.
I'm not saying the Banks turbo doesn't help, it probably wakes that IDI up pretty nice, but you're putting down what? 195 HP to the wheels? Stock 6.0's & 6.4's are putting a lot more than that to the pavement.
I got nothing against the IDI motors, if it works for you, great. But if you're outrunning Powerstrokes, then they're just not trying.
__________________
Jim
'06 F250 6.0 PSD Crew Cab FX4
ARE contractor cap, SCT X3, Airaid intake,
Dieselsite Coolant Filter, '08 Console, High Idle Mod, Bilsteins, Recon clear mirror lights,
Edge Insight, 4" Magnaflow Turbo-back
  #21 (permalink)
Old 10-19-2009, 07:48 PM
oh no, not again!!
my 88 when it was juiced to the max with open pipes and the 5 speed hit 346hp on a dyno with a banks nonwastegated sidewinder turbo running 16lbs of boost..
it is now detuned to around 250 hp.
__________________
Tom
  #22 (permalink)
Old 10-19-2009, 08:41 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
The IDI is a pretty decent engine, but keep on top of the coolant or you'll blow holes through the cylinders. Ford has a special additive to help with this, I would highly suggest using it.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #23 (permalink)
Old 10-31-2009, 12:14 AM
bill11012's Avatar
bill11012 bill11012 is offline
bill11012 is gaining momentum as a positive member of FTE. bill11012 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Lubbockguy1979 View Post
Parts would most likely be cheaper and more plentiful on the 2000. Not that the 94 would be a bad buy but they made the turbo idi for a short peiord of time compared to the 7.3 powerstroke. Also if I recall the turbo 7.3 was basically a ats kit added at the factory. Where the power stroke is a international design. I like the old turbos but I bet parts are harder to find and more expensive
I checked before I got my 90, the parts are cheaper on the IDI.
__________________
my V10 will out pull your PSD any day of the week.
Quote:
Originally Posted by Jmeyer1990
... but i kept losing service in Victoria's Sectret, so I gave up.
Originally Posted by bghnkinf250
Can I retrofit a catalytic converter to my butt?
  #24 (permalink)
Old 11-02-2009, 11:14 AM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
Some of the turbo-specific "hard parts" like some of the exhaust bits are obsolete, but kits seem to pop up on ebay all the time. Everything is pretty much your standard IDI stuff, even the exhaust manifolds are the same.
__________________
1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs. 4" intake tube, ATS upgrade, 4" exhaust w/ Walker 21172, boost & pyro on pillar, Autodim mirror, 16x8 MB Razor wheels w/285/75R16 "MT-R's"
1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners
2008 V-Star 1100 Midnight Custom-Just Cobra slip-on drag pipes for now
  #25 (permalink)
Old 11-02-2009, 06:44 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE.
totally false.
Hate to burst your bubble, but sometimes the wholesalers "forget" to add the additive(s) before shipping to the retailers. I'm spending $20/fill on additive because of their stupidity.
And ULSD *IS* much "drier" than the old LSD or the really old 3000ppm fuel.
I've got a set of Detroit S60 injectors that are screaming for replacement; their degradation in performance can be traced almost to the week to the introduction of ULSD fuel.
-blaine
  #26 (permalink)
Old 11-02-2009, 09:25 PM
parkland's Avatar
parkland parkland is offline
parkland is gaining momentum as a positive member of FTE. parkland is gaining momentum as a positive member of FTE.
346 is a crap load of power for only 16 LBS of boost!
How many RPM's is that at?
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
  #27 (permalink)
Old 11-03-2009, 08:47 AM
oh no, not again!!
3800. the governor was bad.
__________________
Tom
  #28 (permalink)
Old 11-03-2009, 09:43 AM
ghunt's Avatar
Well, with 20.5:1 compression, 16 psi is a damn lot of boost.
__________________
Tags
350 , 73 , 94 , aftermarket , di , dually , expect , f350 , ford , idi , parts , power , pulling , spdtrans , stacks , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
