Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-20-2009, 10:13 PM
onephinesuperduty onephinesuperduty is offline
onephinesuperduty is starting off with a positive reputation.
So I tore into my ESOF tonight and this is what I found
2001 F250 5.4 V8 4X4. ESOF hasnt worked right since I bought it. Switch works, lights on dash work properly, I can feel and hear the transfer case working underneath me, but the hubs wont lock in auto, switch em to manual no problem at all. I took the connector off and checked the 3 pins in the pvh solenoid, center pin only has power from the harness. My assumption is that something must be malfunctioning in the solenoid itself. Going to check into a new one tomorrow. Havent checked into any vacuum line issues yet, however drivers side going into hub was broken, now replaced. Can anyone shed some light on if im headed in the right direction? Thanks in advance!
  #2 (permalink)
Old 09-20-2009, 10:50 PM
dchamberlain dchamberlain is online now
dchamberlain has a great reputation on FTE. dchamberlain has a great reputation on FTE. dchamberlain has a great reputation on FTE. dchamberlain has a great reputation on FTE.
Voltage is on center pin (2) when the key is in run. Pin 1 is grounded by the 4x4 control module to lock the hubs. Pin 3 is grounded to unlock the hubs. You'll need a continuity tester to check for continuity between pins 1 or 3 and ground at the proper time.
Remember that the solenoid is commanded to apply full vacuum for a few moments to lock the hubs, and lesser vacuum is supplied for a few moments to unlock the hubs.
You may have already fixed the problem by fixing the vacuum lines. I'd check that before I did anything else.
__________________
David Chamberlain
2004 F-250 SD, 4x4 FX4, 6.0L PSD
Oregon Chapter Member:
To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 09-20-2009, 11:04 PM
Checked to make sure they were still inoperable, indeed they are, Ill pick up a continuity tester tomorrow at work
  #4 (permalink)
Old 09-21-2009, 12:42 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
You should have a pressure tester and need to clean/grease hubs before you proceed. Unless they have been done.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #5 (permalink)
Old 09-21-2009, 12:46 AM
EXv10's Avatar
Could I manually bypass the module to check the system by grounding 1 and 3 out?
__________________
  #6 (permalink)
Old 09-21-2009, 09:34 AM
Quote:
I don't see why not. I'd disconnect the wiring harness, so there isn't any chance of accidentally putting a voltage to a computer where it doesn't belong. Just put a jumper from pin on of the solenoid to the battery and a jumper from pin 1 or 3 to ground and see if the solenoid opens.
__________________
David Chamberlain
  #7 (permalink)
Old 09-23-2009, 07:28 PM
I installed the new PVH Solenoid for the vacuum tonight, still no go. Took for a test drive. Transfer case works because if i shift it into 4 LOW it limits my speeds. All lights on dash work for 4x4 as well. System works as it should If i get out and lock the hubs into LOCK. Id just like for them to work on auto. Im not aware that it has any vacuum leaks because the HVAC system acts as it should, it doesnt revert to defrost. Any suggestions on where I should go at this point?
  #8 (permalink)
Old 09-23-2009, 07:34 PM
EXv10's Avatar
Did you clean/grease the hubs? Not hard to do ..........check seals in there too. (2 more seals further in)
__________________
  #9 (permalink)
Old 09-23-2009, 08:28 PM
BBQ BBQ is offline
2001 Ford F-250
BBQ is starting off with a positive reputation.
We just finished replacing the ball joint on my similar 01 F250/5.4 CC 4WD and replaced the seals as mentioned above. ESOF worked like a charm when we were done.
The main seal a hell of a fit, the dust seal is easy, and the o-ring was a breeze.
Used the FTE Ball Joint thread for guidance http://www.ford-trucks.com/forums/35...ll-joints.html
  #10 (permalink)
Old 09-23-2009, 09:16 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
Quote:
Try this?
http://www.guzzle7pt3.com/allube.php
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #11 (permalink)
Old 09-24-2009, 09:48 AM
Thanks for the useful replies. Im taking the truck to the Carolinas on vacation for 10 days. However, I ordered the seal kit today so It will be waiting for me when I arrive home. Ill throw it in and let you all know how it goes!
  #12 (permalink)
Old 10-06-2009, 04:51 PM
Well I got the outer seal kit from ford and replaced both big o rings on the outer lip of the hubs and used guzzles lubrication guide to no avail. Hubs still wont autolock? Time for new ones?
  #13 (permalink)
Old 10-06-2009, 10:43 PM
EXv10's Avatar
Pressure test the lines if you haven't. There should be pressure for 15+- seconds to engage and disengage.
__________________
  #14 (permalink)
Old 10-06-2009, 11:04 PM
2000 Ford F-350
Vacuum, not pressure, pulls on the diaphragms that act on the engage/disengage mechanism.
That mechanism is a little like a ball-point-pen's "click on, click off" design.
It's apparent how it works if you take one apart to service it.
Pop
__________________
Email SpringerPop
  #15 (permalink)
Old 10-06-2009, 11:07 PM
EXv10's Avatar
Pop
That's what I meant. I knew I would be wrong sooner or later.
__________________
Tags
autolock , broken , cost , diaphragm , duty , esof , f150 , f250 , ford , hub , selector , solenoid , super , vacuum , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
