Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #61 (permalink)
Old 11-04-2009, 11:34 PM
onephinesuperduty onephinesuperduty is offline
onephinesuperduty is starting off with a positive reputation.
One final question before I tear into this wonderful project. Ive been spraying deep creep into the seam on the hubs for two weeks where the selector knob is for auto or lock, they still wont unfreeze, gotta throw a wrench on them to turn. It sure would suck if i went to all the work of replacing the seals only to find out im gonna hafta replace the hubs too...thoughts?
  #62 (permalink)
Old 11-05-2009, 12:17 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
Though commonly referred-to as "hubs", those are really the hub LOCKS, not the hubs themselves.
Reading this may shed some light on your problem for you:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
I gotta' wonder if locksmith's graphite wouldn't make a better lubricant than something solvent-based.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #63 (permalink)
Old 11-05-2009, 02:46 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
You have to get that stuff into where it does some good. You can't just spray it inside the hub and hope it frees the dials. Drill a hole in the recessed part of the dial (after you take it off) spray some silicone lube in there, put a sheetmetal screw in the hole, let it sit dial side down overnight, and work the dial the next day with pliers.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #64 (permalink)
Old 11-05-2009, 06:55 AM
pilotsaunders pilotsaunders is offline
pilotsaunders is starting off with a positive reputation.
Mine would only turn with pliers on drivers side. I sprayed paint thinner and soaked about one inch of it in thinner for about two hours. worked it with the pliers about ten times and it freed up. Guess What. I did all that work and I'm going to buy new locking hubs,
  #65 (permalink)
Old 11-05-2009, 08:30 AM
My major concern isnt to get the dial to work, though it will be nice. My biggest concern is that in the event i cannot get the hublock dial to free up, with the hubs still lock in automatically with the vacuum system?
  #66 (permalink)
Old 11-05-2009, 08:58 AM
wideglidewoody00 wideglidewoody00 is offline
wideglidewoody00 is starting off with a positive reputation.
I would say to do the lube on the hub locks and while you have it apart make sure the black rubber diaphragm on the inside is bottomed out before putting it back together. And then give it a try. The only thing I did different than the Guzzle write up is when I got to the white plastic washer, he pulled it out with pliers. I pushed it all the way to the bottom with my finger and let up and it released. Good luck.
  #67 (permalink)
Old 11-05-2009, 12:24 PM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
Quote:
Originally Posted by pilotsaunders View Post
As far as the risks outweighing the benefits of changing the top end oil, when you have to have 8 injectors replaced at a cool 4 thousand dollars from ford, its worth a little extra time. Take a look at this video and tell me what you think.
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
I don't pay attention to him. Every now and again he says something okay, but you have to muddle through the other 90% of what comes out of his mouth.
I haven't changed any injectors yet. I have the original 8 that came with the truck and it's got 187K on the odometer and I've only changed the HPOP oil once.
My stub axle is pretty smooth going through the hub bearing, then splined as it gets into the locking hub. Where I see the vacuum line is way back on the knuckle. I don't know. I guess I will replace ALL seals and see what happens.What a Job. Will shoot grease on the bearing so Pop's won't get on to me anymore. LOL
There are 3 seals: the yellow o-ring (hub-to-knuckle seal), the black o-ring (the locking hub seal) and the axle seal (inside knuckle seal that looks like a big disc that seat on the axle itself).
I have the hub off and you can move the stub axle around a little bit. Do you know if the seal is bad or should it move a little around the outer part of the seal? Where did you buy your o rings?
With the hub off, you will definitely feel play in the axle. There are no support bearings or brackets for it. One end slides into the front differential housing (the axle tube really only protects the shaft from dirt and debris) then feeds into the hub assembly through the knuckle. Other than both ends, it's not really supported anywhere else. So when you take your hub assembly off, you really only have "support" for the axle at the differential and the axle seal in the knuckle.
I've never heard of generic o-rings being used. I've bought all of mine through Ford (I never re-use my o-rings).
If you can't get the hub to operate in manual, it most likely isn't going to operate with vacuum. If it's just really "sticky" then M-A-Y-B-E. One of mine was frozen in the unlock position and it took me about 45 minutes of gently "tapping" it around the circumfrence with a mallet until I finally worked it off the axle splines. If the hub is frozen, then chances are the 4x4 system has not been exercised in a while so you may have a combination of problems. I bought mine and the hubs weren't engaging (maybe the 3rd party mechanic WASN'T as good as I thought ), but the light would come on and the transfer case would engage. Turned out to be a bad hub and a solenoid problem (along with a vacuum leak that showed itself after fixing the other two problems ). You could easily have a single point failure, but don't rule out the possibility of more than one problem for your symptom.
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #68 (permalink)
Old 11-05-2009, 01:34 PM
It still might work on automatic if the locking hub is turned all the way to the left while looking at it. This is the auto position.
  #69 (permalink)
Old 11-05-2009, 06:50 PM
brian42's Avatar
But if it's sticking when you manually operate the hub, chances are using vacuum isn't going to yield any better results (ask me and my wallet how I know that one )...
__________________
THE MOOSE
Tags
autolock , broken , cost , diaphragm , duty , esof , f150 , f250 , ford , hub , selector , solenoid , super , vacuum , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
