Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 10-28-2009, 12:18 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
That's plenty of vacuum. Time to check the 3 seals on each side and clean/grease hubs.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #32 (permalink)
Old 10-28-2009, 01:19 PM
onephinesuperduty onephinesuperduty is offline
onephinesuperduty is starting off with a positive reputation.
Which 3 are you referring to? I had the hubs off a few weeks ago and greased/cleaned them. I also replaced the outer seal at that point as well as the clips. Thanks!
  #33 (permalink)
Old 10-28-2009, 06:56 PM
EXv10's Avatar
The black o ring in the outer hub, the yellow o ring on the inner wheel hub and, the lip seal in the knuckle.
__________________
  #34 (permalink)
Old 10-28-2009, 08:29 PM
FireMe FireMe is offline
FireMe is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by onephinesuperduty View Post
Im pulling almost 20 mm hg in vacuum to lock and unlock both sides.
Just to make sure we're clear on a couple of things, 20mm of vacuum is only about 0.75 inches of vacuum, which is pretty much immeasurable on most gauges. I'll assume you meant 20 inches, which is normal like Brent said.
Are you saying your vacuum pump and solenoid are sending 20 inches to the hubs (you hooked the gauge up to the rubber line at the knuckle and then turned the switch to"4x4") or you manually applied vacuum to the hubs and they held at 20 inches? If both of those are true, then your hubs should be locking. If not, then they have to be defective.
When you disconnect the line at the knuckle and hook the vacuum pump to it, you should be able to apply vacuum, around 15 inches or so, and have the hub lock. You can often hear it click when it does. You can now release the vacuum and the hub should stay locked. Applying vacuum at a lower level will make it cycle back off.
If you pull the hub lock out and look in the end where the stub shaft goes, you'll see a piece of plastic. This is the portion that moves with a diaphragm and latches the hub in the locked or unlocked position when vacuum is applied. You can reach in with your finger and manually click it on or off, like a retractable ball point pen. Spin the splined collar to see if it is locked to the outer part of the hub. If you can get it to lock and unlock with a little bit of fiddling, it's probably OK.
Want to drive to Michigan and I'll fix it for you?
Jay
  #35 (permalink)
Old 10-28-2009, 11:34 PM
Sorry on the measurements, inches not mm. Anyways, I was getting 20 inches at the hub knuckle, both going into 4x4 and out of 4x4. I will hook the vacuum gauge up to them and see if theyll lock in that way. Whereabouts in Michigan haha!
  #36 (permalink)
Old 11-01-2009, 01:54 PM
I picked up a mity vac today and attached it at the knuckles. The drivers side holds no pressure at all, the passenger side bleeds out. Im assuming that since ive serviced the hubs im into these other 3 seals. Does anybody have a good writeup or something with pictures regarding replacement of these. Or am i further ahead to just take it to the dealership at this point? Thanks!
  #37 (permalink)
Old 11-01-2009, 02:27 PM
wideglidewoody00 wideglidewoody00 is offline
wideglidewoody00 is starting off with a positive reputation.
Go to the tech folder and look up ball joint replacement. Just follow the steps all the way to pulling the axle out, thats where you will find the last big axle seal. I just replaced my ball joints this week and bought my seals in a kit from FTE Parts guy which is a sponsor on this site for $130.00. Just so you know you will have to make the tool to install the big knuckle seal, it has to be driven in. I just bought one online I believe from Tooltopia.com , the part number is OTC 6695 for $60.00. Make sure you clean up all the surfaces where the seals go. I also bought a $20.00 three jaw gear puller to get the hub off, makes that part of the job alot easier. Good luck
  #38 (permalink)
Old 11-01-2009, 02:50 PM
You can go here and there is a good write-up with pictures so you can see what it would involve doing it yourself. Ball Joint Replacement Write-Up For Ford F250 F350 Super Duty
  #39 (permalink)
Old 11-01-2009, 06:59 PM
So it looks like ill need the seal installation tool as well as these 3 seals
F81Z4A322AA
F81Z3254CB
F81Z1S175HCA
Can someone verify my needs list? Thanks again!
  #40 (permalink)
Old 11-01-2009, 07:52 PM
EXv10's Avatar
You can make the seal installer with pipe, cap, and flange (post in here) but you will have to cut the flange down a bit (to 3 7/8"?) put grease or something on the knuckle lip seal so it goes in easily.
__________________
  #41 (permalink)
Old 11-01-2009, 10:49 PM
Yes you will need two of each of those seals and also the o-rings that go on the auto locking hub. Part number 4C3Z-1K106-AA is a kit. You only need one of these because it comes with two o-rings and one metal retainer ring. As long as one of your retainer rings is good and can be reused. Alot of guys on this site have made that seal driver but I just bought one one line. If you get the seals from FTE Parts Guy all the seals you will need come as a package deal, and the shipping was fast. Hope this was some help.
  #42 (permalink)
Old 11-02-2009, 11:24 AM
brian42's Avatar
brian42 brian42 is offline
brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE. brian42 has a very good reputation on FTE.
Quote:
I made the seal and had it ground down. It cost me less than $30 total (parts and a few bucks to the machinist), but it took a bit of time to get it all done. The home-made tool works like a charm, but you have to be careful that you don't hit off-center because you can easily install the seal cocked at an angle. Not to mention that I did scratch the surface of the seal during installation (it didn't affect the seal, but it did scratch it).
If you are willing to spend a little extra dough and want a real seal driver, Bob has one for sale:
Replacement O-rings for Diesel Engines
Had I known about this before I started, I would have spend the extra $$$ for this. Since you have to tear down a lot (including seals) to get to this seal (and pull the axle out to replace), I would have made the investment to make sure that $30+ seal is on correctly.
Just my .02
__________________
THE MOOSE
2003 F-250 PSD 7.3 Lariat FX4 CC/SB, 4R100, 3.73LS, dual alternators with 188K+ Miles
AIH delete, In-Tank (ITP) and Harpoon Mod, SS HPX, 203F Thermo w/Billet Housing, FTVB, '08 Rear Diff Cover, Headlight Harness (GOS), Zoodad (King Style), 6637, Foil Delete, Engine/CAC boots (Dieselsite), Moog Ball Joints, BFG Mud-Terrain TA KM2 285/75-16
Real Men Redline Less Than 3500 RPM
  #43 (permalink)
Old 11-02-2009, 12:32 PM
That is the same one I bought. It is heavy duty and has the lip on the outer edge to let you know when the seal is in place, worked great for me. $30.00 more than the home made one was worth it to me, now I have it for next time and there will be a next time in the future for ball joints.
  #44 (permalink)
Old 11-02-2009, 07:56 PM
I purchased a genuine ford seal installer off of ebay for a 30 bill. Seemed like the best way to go seeing as how all the aftermarket ones i found were 40 bucks. Seals and all are on order, hopefully everything comes apart as planned!
  #45 (permalink)
Old 11-03-2009, 06:56 AM
Just make sure you clean up all the surfaces that the seals come in contact with. You would hate to have to pull it apart again because of a vacuum. Good luck and let us know how it went.
Tags
autolock , broken , cost , diaphragm , duty , esof , f150 , f250 , ford , hub , selector , solenoid , super , vacuum , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
