Flushing engine/cooling system after oil cooler failed
Old 10-26-2009, 05:40 PM
slowmans's Avatar
slowmans
slowmans is offline
mark can you send me a copy, thanks
slowmans2000@yahoo.com
Old 10-26-2009, 07:16 PM
bismic's Avatar
bismic
bismic is online now
Received 2,489 Likes on 1,726 Posts
Sent them ......
rocky - sorry to take so long
Old 10-26-2009, 07:28 PM
cheezit's Avatar
cheezit
cheezit is offline
there was a post about vc-9 a day or so ago that I provided the flush info for. do a search for vc9 and read that. also simple green or cascade both work well. do not use any soap/ cleaner that foams. I would advise to take the radiator and have it flush at a radiator shop. Also if the heater core can not be cleaned is should be replaced. they not bad like $80.00 for them and easy to install
Old 08-12-2012, 12:58 PM
David Singleton's Avatar
David Singleton
David Singleton is offline
copy of coolant flush procedures
Originally Posted by bismic
"TSB 08-23-1 6.0L DIESEL COOLING SYSTEM CONTAMINATION FLUSH PROCEDURE" is interesting resding. If you would like a copy, I can send it to you.
i would greatly appreciate a copy of the coolant flush procedures..thank you!
pwrstrok21@yahoo.com
mtnrider28
10-31-2016 09:36 AM
BryanStein
09-23-2015 10:54 PM
superduty1967
10-01-2012 09:11 PM
JonArmy
03-12-2012 07:33 AM
dawiz
04-09-2011 05:40 PM
Quick Reply: Flushing engine/cooling system after oil cooler failed
