Help with Lug Pattern ?
I am looking to buy new rims and can figure out what my lug pattern is ? I have a 1975 f100, 3 speed manual column shfft, 302, v8. 5 lug rim pattern but need to know exact size so i can order rims. I like the american racing hopster rims but am not sure if they will fit. Let me know if anyone can help. Thanks guys.
Jeff
Jeff
I don't remember the years for sure, but there were a few years that did do that. It may have been more of an earlier thing, but there were some. I'm not finding the info now to back it up, but have seen mention of it beforem, but it was only for a short time if I recall. And maybe my memory is just faulty...
OK, I just found it, I was too old, it was an 80's thing...
Go here. http://adaptitusa.com/index.asp?PageAction=Custom&ID=4
It tells you how to measure your bolt pattern
Jeff
Jeff
Yup - those F-100's were the VERY light duty trucks. Frames are known as the "swiss cheese frames" for obvious reasons...
Some 1980/83 F100 wheels are 5 lug on a 5.50" bolt circle.
Some 1980/83 F100 wheels are 5 lug on a 4.50" bolt circle.
Not only are the wheels different, but so the front/rear brakes, shocks and springs.
Did'ja know that you could not get 4WD or a Super Cab on 1980/83 F100's?
Did'ja know that the largest engine available in these trucks was the 302?
Did'ja know that 1982/83's were offered not only with the anemic 255 V8, but with the horrid 3.8L V6 as well?
We used to call the 3.8L the miracle engine. If one was able to get 60,000 miles from the terd without blowing a head gasket or replacing the timing cover...it was a miracle!
No F100's after 1983.
ALL 1975/96 F150 wheels are 5 lug, 5.50" bolt circle.
got any pics of the "hopster"? Changing hubs to change lug pattern is more trouble than it is worth usually.
You might see if whoever makes the wheel offers it without the lug holes drilled - then you can have a machine shop drill the lug holes for you.
OR - if the wheel is offered in a 5x135mm or maybe even 5x5 lug pattern you MIGHT be able to get the lug pattern drilled and sleeved to change it to 5x5.5. Any GOOD wheel shop could do this. "Good" usually means a mom and pop type shop, not the Big O tires or other large chain stores that just sell wheels/tires and don't really work on much...
