How do I disable speaker for door ajar alarm? - Ford Truck Enthusiasts Forums
Old 09-20-2009, 06:41 PM
Florida F250 Florida F250 is offline
Florida F250 is starting off with a positive reputation.
Hey all,
I just purchased a 2000 F-250 (extended cab, extended bed); it's my first powerstroke as I owned an IDI prior to its purchase.
- How do I disable the speaker for the door ajar/seat belt/low fuel alarm? IT HAS TO GO!
- Also as a new powerstroke owner, are there any spare parts/sensors, etc. that I should keep handy, just in case? (ie. I always kept a spare glow plug relay in the IDI F250)
Thanks in advance for your sage advice.
Florida F250
Old 09-20-2009, 07:33 PM
triskit16's Avatar
triskit16 triskit16 is offline
triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.
No idea about the door ajar thing, but keep a spare CPS in the glove box with a 10mm socket as well.
Old 09-20-2009, 07:40 PM
nissandoc's Avatar
nissandoc nissandoc is offline
nissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to all
The owners manual will tell you how to disable the seat belt alarm and auto door lock. Never heard an alarm for low fuel or door ajar, just the idiot light.
Old 09-20-2009, 07:49 PM
farmdad's Avatar
farmdad farmdad is offline
farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.farmdad has a great reputation on FTE.
If you are referring to the dinger for the key in the ignition, there are a couple ways to disable that. Some remove the wire from the ignition switch which allows reconnecting the wire when you sell the truck.
Many cut the black or dark gray wire with a pink tracer that is located on the steering column. I removed the lower dash cover, found the wire, cut it and taped off the ends.
There are many threads about this mod that give much more detailed instructions than these. Others will give more advice to do this.
Old 09-20-2009, 09:36 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
Old 09-21-2009, 07:39 AM
farmdad's Avatar
Good job on the link, Jason. I gotta rep ya this way.
Old 09-21-2009, 07:59 AM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Lightbulb New Approach to old problem
To "totally" disable the the alarm/dinger, you have to access the speaker behind the instrument gauge cluster. Remove the instrument guage cluster and you will find a small round speaker with a hole in its center. It is attached directly to the back of the cluster. You can verify its location, while the cluster is still plugged in, by activating the alarm with key in, door open, etc. I put a screw in the hole of the speaker to wedge it and keep it from vibrating. It still had a barely audible sound, but can't be heard with the dash back together. I did this on my friend's '00, '03, '05, & '08 trucks. It wis disable the alarm, at the source, for "all" purposes. This is the way I have found to do it "completely", takes less than 10 minutes to accomplish, and is reversible.
Old 09-22-2009, 09:26 PM
jcrammell's Avatar
jcrammell jcrammell is offline
jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.jcrammell has a very good reputation on FTE.
I still have the chime. I followed Kwikordeads thread about disconnecting the black and pink wire. Was very easy but my door open chime still dings when the key is in the accesory position. Does anyone have a solution for this problem yet? Would really like to know how to take care of this problem.
Old 09-23-2009, 12:16 AM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
If I remember right, there is a connector under the drivers seat, accessable from the rear. If you unplug it you will disable the gong. I work out of my truck and I enjoy the radio when I am working. The gong drove me crazy.
Old 09-23-2009, 08:11 AM
mueckster's Avatar
Quote:
That's the other thing that disconnecting the wires for the seatbealt, key switch, and owner's manual procedures won't cure. I researched this a few years back and found if you disconnected the the trigger wire, to the GEM, from the door switch you could eliminate the alarm, but this would also eliminate the interior light functions, too. There is no easy solution, other than killing the alarm itself or putting a switch in this wire.
Old 09-23-2009, 11:27 AM
rocknocker rocknocker is offline
rocknocker is starting off with a positive reputation.
If you pull the lower steering column cover, removed the key cylinder, and then removed the wire on the cylinder, it will dissable the door ajar chime, however it will still chime for lights left on and also for a few seconds when the ignition switch is first turned on. I have done this on two trucks. It is a clip with a metal contact for the key with a purple wire with black trace I think.
Old 09-23-2009, 02:29 PM
jcrammell's Avatar
Quote:
Did this but it still dings at you when the key is in the accesory position. Any ideas on that?
Old 09-23-2009, 10:09 PM
mueckster's Avatar
Quote:
I made a mistake in my earlier post. I did this on an '05 and '08. They have the chime on the back of the instrument cluster. I'm not sure if I did this to the '03 (instrument cluster is slightly different w/ a 6.0). My '01 has the chime in the GEM module. Sorry for any confusion. It was a while back and I have occasional CRS.
Old 09-23-2009, 10:28 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
I made a mistake in my earlier post. Sorry for any confusion. It was a while back and I have occasional CRS.
Shame shame. We have no idea how many folks have taken the cluster off and screwed themselves....I mean put a screw somewhere. Oh the humanity.
Edit, but seriously, Jim can you edit that out so nobody attempts it?
Old 09-23-2009, 11:16 PM
mueckster's Avatar
Thanks for making me feel even worse.
If it makes you feel better, I took my cluster out tonight to take some pictures and realized my mistake. I did, however, polish my lens while it was out. SSSOOO, it wasn't all for naught.
Disable alarm- someone must know how! MeanGene427 Explorer, Sport Trac, Mountaineer & Aviator 2 07-14-2015 07:00 AM
Possible to Disable Door Ajar Chime But Not Headlights on Chime moymurfs 1999 to 2016 Super Duty 5 04-28-2015 07:22 PM
ILLUMINATED ENTRY DOME LIGHT gene daniels Electrical Systems/Wiring 0 12-22-2012 12:39 AM
disabling door alarm Dvandy21 1987 - 1996 F150 & Larger F-Series Trucks 12 12-23-2010 08:30 PM
Door Ajar Alarm SURFSHR 1997 - 2003 F150 3 01-31-2002 02:17 PM
Tags
07, 1999, 2000, 2001, 2004, ajar, alarm, diesel, disable, door, f150, f250, ford, location, speaker, truck, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
