2002 f350 leveling kit - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-20-2009, 03:59 PM
rtazz17's Avatar
rtazz17 rtazz17 is offline
rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.
I searched and found lots of threads but most are old or dont address my specifics so hear goes.
I have a 02 f350 7.3 diesel crew cab lariat and want to get rid of the "nose dive look"..Im thinking about a 3 inch kit.Its ok if the front is still low by an inch.This is IMPORTANT...I need to still fit the truck in my garage and have 2.5 inches to spare at roof line now.(I believe if I lift the front 3 inches the roof line will go up by about 1.5 inches,correct me if im way off)
I dont know much about leveling kits but from reading I think I want a hanger kit to preserve the way it rides.I believe I will also need a new track bar,right?I have new billstien shocks(2 MONTHS OLD} all the way around,will I have to replace my fronts again with leveling kit?I dont want to have to do any work on the rear for anything..
Any recommendations on what to buy and why?Is there such thing as an adjustable height leveling kit?Trying to stay in 5 to 700 dollar area..
I should also say I have asteering stabilizer already,the tires I have and will keep ar 285*75*16 and the ground to fender rear hieght is 43.5 inches and front is 39 inches....
Old 09-20-2009, 04:19 PM
CTYankee's Avatar
CTYankee CTYankee is offline
CTYankee is gaining momentum as a positive member of FTE.
At my shop we like the Ready-Lift leveling kit. In fact, I just had one installed in my 2005 F350. It gives the truck a level, lifted look but the lift is only a couple of inches. Ride quality seems to be pretty good, but we will nonetheless install a steering stabilizer as well to guard against excessive bump steer.
Old 09-20-2009, 05:39 PM
rtazz17's Avatar
Quote:
I dont think that kit is available for an 02...My truck has leaf springs and I believe that kit is for coil springs..
Old 09-20-2009, 06:48 PM
rtazz17's Avatar
So after looking at my leaf springs Im trying to decide if they are worn or correct. They are just about flat,straight across. Maybe if that indicates worn I should get a leaf pack leveling kit.Im just worried about getting in my garage with the hieght.Would hate to add the kit and not fit in my garage.. Lol.. Dont know what to do....
Old 09-20-2009, 06:52 PM
jasfaa's Avatar
jasfaa jasfaa is offline
jasfaa is starting off with a positive reputation.
I can't remember everything that came with my leveling kit on my 04, but I remember I also put new shocks on as well. I think it was, shocks, shackle kit and alignment. Its been two trucks ago so I am starting to get fuzzy on remembering.
Old 09-21-2009, 10:54 AM
rtazz17's Avatar
bump up
Old 09-21-2009, 11:36 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
superduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud ofsuperduty4x4 has much to be proud of
I have a Pro Comp shackle/hanger kit waiting to go on.. supposed to give 2" of lift up front. If I ever get it on, I can get a before/after measurement to the roof line for ya.
Old 09-21-2009, 01:38 PM
rtazz17's Avatar
I think I may just try a shackle kit...I know it will stiffen the ride some but its easy to put on and take off...The easy taking off is important because its gonna be a tight fit in the garage..I know a hangers would be a better option with the shackles but if I need to take the shackles off because it wont fit in the garage this is the easiest way..Can I add hangers later if the height works for me?or does that add even more height?Heres the link to the kit http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Old 09-21-2009, 02:24 PM
Lots of guys use the shackle only kits and are happy, to me it seems like a half azz approach.
Here's an easy way to tell if your rig is gonna fit in the garage or not... put a nice heavy duty jack under the center of the front axle. Take a measurement from the ground to the top of the front wheel arch. Jack the truck up until you get 2" higher than that number, then measure to the roofline.
2000 f350 7.3 lift suggestions Melendez7.3 1999 - 2003 7.3L Power Stroke Diesel 7 01-05-2015 07:13 PM
Suggestions on removing front lift blocks (unfortunately I am serious) Blown 331 1999 to 2016 Super Duty 9 04-26-2013 10:45 AM
lift questions? FordOwnerJoey 1987 - 1996 F150 & Larger F-Series Trucks 0 10-22-2012 10:10 PM
cost effective lift/level? concerns? shocks? DieselDreamer Modular V10 (6.8l) 16 02-17-2012 04:22 PM
to lift or to level? xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 18 10-25-2010 07:24 PM
Tags
15, 1999, 2000, 2002, 350, comp, f250, f350, ford, kit, kits, leveling, ma, ok, pro
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
