Replacing Power Steering Pump Hi Pressure Hose - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-20-2009, 04:19 PM
pgw85706 pgw85706 is offline
pgw85706 is starting off with a positive reputation.
The hose has failed. Actually the leak is in the metal tubing at the lower end.....completely corroded through.
My problem is I cannot get a wrench on the connector where it goes into a block. The block has 3 other connectors but it sits directly on the front end cross frame member. How do I get a wrench on that compression connector?
I believe that block serves to exchange heat....is that correct? There is another tubing directly above the PS pump hose which seems to route to a small radiator coil just above the axle.....and this tubing is terribly coroded too and figure might as well replace it when I get that PS pump hose off.
Any suggestions on how to remove the connector? I'm thinking to just cut the tube and slip a 18mm socket onto the connector.
Old 09-20-2009, 09:37 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
That will work to get the old one off. you still have to figure out how to get a wrench in there to tighten the new one.
Old 09-21-2009, 12:16 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
I would try a flare nut wrench, craftsman of course.
My 1999 Ranger Service Manual doesn't have any specific instructions to remove the high pressure hose. It does say that if the hose has a seal ring the seal ring must be replaced. The replacement hose you get should have it installed already.
Old 09-21-2009, 04:50 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is gaining momentum as a positive member of FTE.
On my 03 I had a high pressure hose leak. The hose was replaced by dealer and it still leaked. As rusty as the metal on mine was I think the main culprit was the O ring and the fact that the mounting location sat at an angle that allowed road salt to get in to the connection and corrode it. The entire rack had to be replaced to stop the leak but the dealer had to foot the bill due to their improper original diagnosis.
2005 PS Pump Removal AA3NK 6.0L Power Stroke Diesel 10 10-23-2013 09:33 AM
05 Escape power steering hose 05Escape Escape & Escape Hybrid 0 09-22-2013 11:38 AM
Coolant Return Tube sddesigns Modular V10 (6.8l) 3 10-28-2011 10:52 PM
Windstar Heater hose fordguy21 Cooling, Heating, Ventilation & A/C 1 03-23-2011 01:49 PM
Oil leak out of braided hose below fuel filter Lushman 1999 - 2003 7.3L Power Stroke Diesel 8 06-02-2010 12:45 AM
Tags
1997, 2001, end, f150, fluid, ford, hose, leak, leaking, lower, power, pump, ranger, removal, replace, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
