Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #256 (permalink)
Old 11-01-2009, 10:13 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
Originally Posted by oddshot View Post
I think there's a 20 page limit to threads on this here forum. We're fixin' to plumb run outta room soon
Huh???
http://www.ford-trucks.com/forums/827210-part-vi.html
  #257 (permalink)
Old 11-02-2009, 02:31 AM
greyghost85's Avatar
greyghost85 greyghost85 is offline
greyghost85 is gaining momentum as a positive member of FTE.
girfriend had a nice big Mercury that would "count down" the gallons remaining in fuel tank. she would be driving thru the Ozarks, down to 1 gal remaining! I certainly dont understand that mindset, but it works for her!
__________________
darrell 86 F250 6cyl flatbed
  #258 (permalink)
Old 11-02-2009, 12:56 PM
TheKirbyMan TheKirbyMan is offline
TheKirbyMan is starting off with a positive reputation.
We used to have an '85 Caddy that had a similar feature. The car was a major lemon though, alot of times we couldn't run the gas out of it because it'd die for whatever reason before it ran out.
__________________
1981 F-150 Custom 302/C6 9"
FORD: The Best Never Rest!
  #259 (permalink)
Old 11-02-2009, 09:48 PM
dcassidy dcassidy is offline
1985 Ford F-150
dcassidy is starting off with a positive reputation.
Ok so here's the latest update.
I've been driving the truck back and forth to work for about 1 1/2 weeks now and I would say it seems that I might be good for ANOTHER 200,000 miles.
So far I can only find one problem, and that is I think the transmition is going south.
My reason for saying that is every so often (rarely) when I take off from a stop it feels like it has less power. Almost like it's slipping. And when it does, it takes longer than usual to shift into second. Then at the next light it will be fine and won't give me anymore problems for a few days or so. I can't really explain it better than that. So sorry if that's not enough info.
Other than that I think I got this old moneypit is running pretty good. It idles good, starts easy, doesn't overheat or smoke, the heater works, windshield wipers work, and all the lights work now.
I still need a front end alignment but my son's first birthday is in two days so I don't have alot of cash. But I got it driving straight so it will be fine for now.
  #260 (permalink)
Old 11-02-2009, 10:12 PM
what does the tranny fluid look like? pink or dark? mine is blackish
__________________
  #261 (permalink)
Old 11-02-2009, 10:13 PM
@greyghost Might wanna take care of that...lol
@dcassidy What transmission do you have?
I'd check the fluid level and color first. If it's low, add new fluid to bring it back to the OK line. If the color of the fluid is dark and/or it smells burnt, you might need to change the fluid.
If it's a C4 or C6, you could also try replacing the modulator valve and see if that helps. I helped another member on here whose C6 was shifting funny, and when he replaced the mod valve, it shifted better. It's a simple job, probably no more than 30 minutes worth of work.
__________________
Tags
1985 , 1986 , bad , f150 , ford , head , love , make , modulator , oldtrucks , overheats , rtucks , smoke , smokes , straightline , transmission , truck , trucks , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
