Help! How to disassemble dashboard? (2008 F250) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-19-2009, 02:55 PM
the Goat the Goat is offline
the Goat is starting off with a positive reputation.
Can anybody give some hints on how to disassemble the dashboard on my 2008 F250 FX4? I removed the few screws I could find. But most of the panels seems to be stuck behind the central panel (where the radio and A/C controls are). For the life of me I can't figure how to take it apart.
Old 09-19-2009, 03:11 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
Are you trying to remove the entire dash, or just to get at the stereo?
Old 09-19-2009, 03:15 PM
LMS Residential's Avatar
LMS Residential LMS Residential is offline
LMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputation
If you google radio removal for 08 Ford F250, you'll be able to pull up printable instructions from one of the dash kit manufacturers that clearly detail stripping out the center dash. Actually real easy, carefully pry out the two small panels that house , I think, the cigarette lighter and the airbag switch which exposes 2 hex bolts, remove those bolts and, starting at the bottom, carefully pry the center cover off. The majority of the cover is held in place with somewhat fragile clips. I'm not real dainty and managed to do mine without breaking any. A small set of pry picks helps.
Old 09-19-2009, 03:33 PM
Quote:
I'm trying to see the wires behind the center dashboard panel. I'm looking for the wiring harness plug for the "mirror defrost switch". Not sure if it will be back there or not. So far I did find an extra wiring harness plug behind the spare change holder (I was able to pry it out). This is where the trailer brake controls go (I don't have the factory trailer brake controller). So maybe the defrost wires will be there also.
Old 09-19-2009, 03:36 PM
Quote:
I tried google but didn't find anything with details. I will try removing the cigarette lighter and mp3 player panels again (I stopped prying on them earlier because I wasn't sure if they popped out or not).
Old 09-19-2009, 03:56 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
not the airbag switch...
The panel on the lower left with the 12v power will pop out with a small flat screwdriver from the bottom.
The panel on the lower right with the Aux Line (blank plate for AM/FM only) will pop out the same way
behind these panels are the only two screws holding the center section on...
once you get these... put your hands in those holes with your palms up and your fingers pointed toward the top of the dash, and pull back toward you...
don't pull far without unplugging the other 12v outlet, the airbag switch, and anything else that is plugged in...
Old 09-19-2009, 04:10 PM
Quote:
I got no joy prying from the bottom. But when I tried prying from the top it popped right out. Other then that the directions were spot on. Thanks everybody.
Looks like the mirror defrost switch is integral with the A/C controls. So there is not an extra unused wire harness like I thought there might be.
Any know where I can get a wiring diagram?
Old 09-19-2009, 04:20 PM
TexasRebel's Avatar
the workshop manuals at motorcraft.com will have them... but you'll have to buy access
Funny about prying from the top... On mine there are little slots on the bottom so you can slip a small tool in and it's more of a pulling motion than a prying one.
Old 09-19-2009, 05:15 PM
smotrs's Avatar
If all your trying to do is get the center where the stereo is out, take a look at the following PDF.
Just two screws and slowly work it off.
Old 09-19-2009, 05:17 PM
smotrs's Avatar
Whoop, never mind, see you got it off a couple posts higher.
Old 10-26-2014, 07:02 PM
Joe Benavidez Joe Benavidez is offline
Joe Benavidez is starting off with a positive reputation.
Can any one help me remove the entire dash board of my 08 6.4 . I cannot get it
Dashboard Lightbulb Replacement - Major Job? Syncrowave 1999 - 2003 7.3L Power Stroke Diesel 8 02-04-2016 12:06 PM
Dashboard Square Question 1999 F350 kiaya611 1999 to 2016 Super Duty 3 01-15-2016 01:52 PM
Dashboard Air Duct Does Not Switch Properly Fred Furrer Ranger & B-Series 7 03-29-2015 01:28 AM
F-250 6,4 Diesel Fx4 2008 123sfbk 1999 to 2016 Super Duty 3 01-22-2015 06:44 PM
2008 door on a 2001 ramsay 1999 to 2016 Super Duty 11 07-04-2014 07:15 PM
Tags
08, 2001, 2005, dash, dashboard, disassemble, disassembly, duty, f150, f250, ford, pull, radio, removal, remove, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
