E250 Blower Fan Does Not Work - Ford Truck Enthusiasts Forums
Old 09-19-2009, 09:41 AM
TheRed TheRed is offline
TheRed is starting off with a positive reputation.
Here's what I have and what I've tried:
I'm not a mechanic, but I have time and no money, so I'd like to fix this myself if I can.
2000 E250.
4.2 Litre
The blower motor stopped working over the course of weeks. It began by not turning on immediately on starting the vehicle, but would come on after a few moments. As time passed (three weeks) the fan would take longer and longer to fire up after starting the vehicle. Once the fan came on on any particular trip it would stay on (and I could turn it on an off successfully) for that trip. For the past two weeks it has not worked at all.
So far I have:
Checked the 50 A blower motor fuse - which looked perfect - and cleaned it.
Replaced the 50 A blower motor relay.
Checked for power at the relay - I do have power there in the 50A side, and do have power to the coil side as well. The coil side power does switch on and off with the HVAC control switch on the dash.
I have no power coming to the fan motor speed control switch on the dash. As I've said the HVAC control switch is sending power to the coil side of the relay, and seems to be correctly controlling the dampers and the AC compressor.
I tried to remove the Fuse and Relay block under the hood to get to the back side and look for loose connections but didn't succeed in getting it out.
Please give me your advice and what to try next.
Thanks!
TheRed
Old 09-19-2009, 10:02 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
If you have power to the relay coil (86) and common (30) and no power out of the relay (87) with a new relay then you have a bad ground at ground G100.
G100 is located on the left front of engine compartment, at LH upper radiator support.
Old 09-19-2009, 10:34 AM
I'll try it ASAP
subford,
Thanks! I'm on my way out to the driveway.
TheRed
Old 09-19-2009, 04:39 PM
Subford,
Well, while we were checking for G100 we noticed that the blower motor resistor in the back of the blower motor housing was looking bad - turns out it had corroded and burned out quite badly. I've just finished putting that back together - a new thermal limiter and a new plug as well.
This did not cure the problem, so now I'll go and look for G100 again.
You may wonder why we were looking by the battery for G100, when you clearly said it was in the left front. All I can say is, "Oh, you meant THAT left front..."
TheRed
Old 09-19-2009, 04:45 PM
By the way, the relay sounds like it is functioning - audible clicks in response to turning the HVAC control on the dash "on" and off.
Old 09-19-2009, 06:35 PM
Last note for the day:
I looked for any accessible grounds under the hood and attempted to tighten them all. I did find one by the battery that I was able to tighten up a bit, though it was not wiggly loose by any means.
I then checked for power at the fan motor plug and have power there. Whether or not I had it there before I don't know. In any case, the fan turns now - but very slowly and loudly.
So, it seems to me that the fan motor is toast. Is is possible that the motor, when going out, burned up the Blower Motor Thermal Resistor? In other words, did the motor, as it was going out, cause the rest of the trouble, or are the two problems merely coincidental?
My plan for tomorrow is to get a blower motor installed.
TheRed
Old 09-19-2009, 09:19 PM
subford's Avatar
Quote:
If the relay clicks then G100 is OK.
By the way the left side is the drivers side.
High speed bypasses all the resisters so if it turns slow at high speed setting then I would say you have a bad fan motor.
Old 09-22-2009, 06:31 PM
The project is done
Here's the final result:
The thermal limiter and the plug that goes into it were both corroded and cooked, so I replaced them.
I found one ground that was able to be tightened, but I'd hardly call it loose.
The fan motor was making funny noises - when it finally came on after replacing the limiter and plug - so I replaced it. The first new motor ran for about 20 minutes then died. So far the free replacement is doing well. And now that I've replaced the thermal limiter I have four fan speeds again, rather than the one I've had for the last three years.
Thanks, SubFord, for your very quick responses, and thanks to the FTE creators and maintainers - you helped this rookie get the job done.
TheRed
Blower motor not working in 2009 e350 MikeBlansfield 1968-2013 Full Size Vans 7 10-16-2014 07:02 AM
Blower stopped working bill57 1997 - 2003 F150 7 06-18-2014 07:46 AM
e350 blower dockwatson Cooling, Heating, Ventilation & A/C 6 03-12-2014 09:42 AM
blower not work? Super Econoline 1968-2013 Full Size Vans 17 05-18-2013 09:34 PM
99 blower not working snakedoc 1999 - 2003 7.3L Power Stroke Diesel 7 12-23-2010 06:35 PM
Tags
2002, 250, 99, blower, dash, e250, f150, f250, fan, fuse, location, motor, relay, resistors, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
