02 7.3 check engine light - Ford Truck Enthusiasts Forums
Old 09-19-2009, 06:33 AM
asphaltcowboy1074 asphaltcowboy1074 is offline
asphaltcowboy1074 is starting off with a positive reputation.
My light comes on when I am driving highway speeds. It never stays on long, 5 min or so and as soon as you turn the ignition off, it clears the code so I cant get a read on it. It happens when downshifting and accelerating to pass or pull a hill. Any ideas? I do have a superchips tuner installed but I have tried both with and without programming installed with the same results. Other than the light coming on, the truckruns fine. I have about 125k on it and this has also happened through 2 cam sensors.
Old 09-19-2009, 07:09 AM
greedy737 greedy737 is offline
greedy737 has a good reputation on FTE.greedy737 has a good reputation on FTE.greedy737 has a good reputation on FTE.
Maybe an over boost thing, but if the light came on it stored a code. How did you read the codes?
Last edited by greedy737; 09-19-2009 at 07:11 AM. Reason: sorry I didn't see you said downshifting to!
Old 09-19-2009, 10:50 AM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.SuperDoodie has a very good reputation on FTE.
I suspect if you were to pull the codes with a scanner, its gonna be either P1211 or an overboost code.
Old 09-19-2009, 01:03 PM
Is that anything to worry about or is there something I can do to fix it?
Old 09-19-2009, 08:59 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
Depends on the code.
Old 09-19-2009, 09:43 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I thought the Superchips tuner could pull codes? Just because the light goes out doesn't mean the codes dissapear. The PCM will remember the codes for a while, even after the light goes out.
Another P1211 guess here.
Old 09-19-2009, 10:45 PM
zx250's Avatar
The 1705 will, but not sure what he has
Old 09-20-2009, 12:35 AM
I have the new controller. Just sent themmy old one and they sent me the new version. I will see if I can pull the code tomorrow. I know I could pull codes withthe old one but I never got a code for this scenario. I willpost what I find.
running lights tail lights and dash lights 6.9idiatsturbo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 08-15-2016 06:54 PM
HID's = ABS light???? xmontex4 1999 to 2016 Super Duty 11 07-22-2016 07:28 AM
Battery light andym Excursion - King of SUVs 9 05-19-2015 08:37 PM
87 Ranger Dashboard Lights AaronEZ Ranger & B-Series 7 12-10-2014 09:49 PM
Wierd Headlight problem BigLoo Aerostar 18 08-05-2011 01:39 AM
Tags
01, 02, 2003, 73, 73check, check, codes, diesel, engine, f250, f350, ford, hill, light, lights, pull
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
