Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-18-2009, 07:34 PM
LotusJoe LotusJoe is offline
LotusJoe is starting off with a positive reputation.
King Pin replacement
I am in the process of rebuilding the the king pins on my 1961. Any suggestions on how to install the new bushings if you don't have a press. Also where might I get a reaming tool for the bushings?
Thanks
Joe
  #2 (permalink)
Old 09-22-2009, 06:30 PM
francobones francobones is offline
francobones is starting off with a positive reputation.
Hi, my suggestion is to take it to a garage/repair shop (not sure what you guy's call it in the US), the mechanic who did my kingpins had to borrow a heavier duty press (5 ton I think) as he couldn't do it with his one, I don't think they are an easy job but someone here might know better.
Frank
  #3 (permalink)
Old 09-24-2009, 12:58 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw is gaining momentum as a positive member of FTE. 66gpw is gaining momentum as a positive member of FTE.
Vintage -vans has a few posts of the subject. where guys have trouble areas and what is needed to be done. Do you go with nylon bushings or brass. With bras you need to have it reemed and with nylon they can be pressed. The joys of removing it yourself or having a shop do it.
I just suggest checking the site out and see if their forums can help withan answer.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
86 F150 Exploere XLT Ext cab
66 Merc 1Ton Flat deck
78 F250
Tags
1956 , 1999 , bushing , f100 , ford , install , installation , king , kingpin , pin , pins , replace , replacement , replacing , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
