Bondtite??? - Ford Truck Enthusiasts Forums
Bondtite???
Old 09-18-2009, 04:39 PM
Oakroadjoe Oakroadjoe is offline
Oakroadjoe is starting off with a positive reputation.
Bondtite???
Just bought some Bondtite xl microcel light body filler.Is it the same as Bondo?Ie,put on,worked,mixed the same.Any one out there ever use it?? thanks Joe
Old 09-19-2009, 09:05 PM
Chaosracing's Avatar
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.Chaosracing is gaining momentum as a positive member of FTE.
Bondo is a brand name of body filler. Its also the generic name that alot of people not in the body trade call body filler. Most of your fillers are pretty much the same as far as mixing, applying and sanding. I never used the Bond Tite (never heard of it either) so I dont know about the performance. I usually use Evercoat systems for fillers.
Old 09-19-2009, 10:03 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Personally, I don't like Bondtite or Evercoat.........prefer Dynatron brand, but that's just my lowly opinion.........T/M
Old 09-20-2009, 05:02 PM
Thanks
Thanks for your thoughts on the body filler.FTE always gets the answers.
Is moog and xrf the same company?? Vince79vette Excursion - King of SUVs 13 12-11-2014 09:24 AM
aftermarket lightning center caps 4Cammer72 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 12-20-2010 07:37 AM
BDS/ Dick Cepek 6'' lift..same? v8xploder 1978 - 1996 Big Bronco 8 01-13-2010 11:20 AM
Are the 6.0 and V10 5sp trannies the same? ScubaCat 1999 to 2016 Super Duty 18 07-31-2009 09:26 PM
C6 trans cases: are they the same? cjdm_1 Clutch, Transmission, Differential, Axle & Transfer Case 4 01-13-2002 10:48 AM
Tags
60082, body, bodyfiller, bond, bondtite, buy, filler, light, micro, microcel, microsel, tight, tite, titexl, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
