Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 10-25-2009, 04:59 PM
deve deve is offline
deve is starting off with a positive reputation.
do you have any idea how much that will cost? also how much power do u get from balancing.
  #62 (permalink)
Old 10-25-2009, 05:11 PM
doug1222556's Avatar
doug1222556 doug1222556 is offline
doug1222556 is gaining momentum as a positive member of FTE.
Usually about $175-$200. Having lighter than stock components is usually less expensive because they drill the counterweights to acheive the balance. Adding metal gets expensive in a hurry.
It's not about gaining HP, without the proper balance the motor would shake so bad it would jump out of the vehicle. An imbalance reaction that severe can be from an imbalance of weight equal to a quarter.
  #63 (permalink)
Old 10-26-2009, 09:06 AM
what about cross drilled crank what does that do?
  #64 (permalink)
Old 10-26-2009, 11:01 AM
A stock crank has only one hole per rod journal for oiling. Crossdrilling is adding another hole at a 90* angle to the exsisting one. It helps insure oil flow and constant oil pressure to the rod bearings.
  #65 (permalink)
Old 11-06-2009, 10:02 AM
The internet bill wasn't paid so i could not get on but its back on now so its all good. I have been looking at pistons rings but they all look about the same to me. does it just depend on brands you prefer.
  #66 (permalink)
Old 11-06-2009, 07:05 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
You should use the rings specified by the piston manufacturer for their pistons......
  #67 (permalink)
Old 11-08-2009, 05:52 AM
With the build im going with should i use stronger rings than the one that Keith
Black makes?
  #68 (permalink)
Old 11-08-2009, 06:28 AM
I didn't see anything special about the rings for those pistons. They are standard 5/64, 5/64 3/16 rings. Personally I like the E251K Moly rings like I sent you a link for a while back. I don't know anything about Keith Black rings, you might want to check with Summit and verify that they will interchange just to be sure. You could run any ring you want from stock cast on up because you're not running that high of CR and no boost or juice.
  #69 (permalink)
Old 11-08-2009, 09:33 PM
First of all.... why? Its a naturally aspirated engine so you dont need total seal gapless etc rings to keep supercharger/turbocharger blowby down....
Second...... the harder the rings you choose the faster they will wear down the bores and therefore the more quickly the engine will wear out......
  #70 (permalink)
Old 11-09-2009, 02:57 PM
93F22A6 93F22A6 is offline
93F22A6 is starting off with a positive reputation.
Quote:
Better compression, more vac, less blowby, it's more of a question of why not than why in the first place.
__________________
76' F-100 302 C4
DD-93' Accord 5spd
  #71 (permalink)
Old 11-09-2009, 11:57 PM
I was thinking these rings would be a good choice Total Seal Piston Rings C9090-30 - Total Seal Classic Street Piston Rings - Overview - SummitRacing.com
  #72 (permalink)
Old 11-10-2009, 12:40 AM
Quote:
That's easy- $105 vs. $20. $40 for Moly's. Last time I checked, there was a budget on this engine- but it seems to be growing.
Compression and blowby shouldn't be a problem if the machine shop work is done correctly. Usually parts that cost 2 1/2 to 5 times more are better. I have found that when the money runs out before the engine is finished, they usually don't run at all. The parts wind up at swap meets and Ebay.
I'm not saying it's going to happen here, but there are a lot of costs involved in a build and the kid has a long way to go.
With some of the choices he's making he could have went with a stroker.
  #73 (permalink)
Old 11-10-2009, 10:43 AM
good point doug. so then these should be fine Sealed Power ZE377K30 - Sealed Power Performance Piston Ring Sets - Overview - SummitRacing.com
  #74 (permalink)
Old 11-10-2009, 12:40 PM
OK. Let's back up a second. I told you I didn't know anything about KB piston rings and frankly I don't know all that much about KB pistons.
I remember someone talking about hypers being brittle and breaking the top ring land. This may be due to using KB pistons and the wrong rings.
If you remember, I said you should get some Tech advice to make sure there wasn't a hidden difference in the rings.
I've been doing some research and info on the KB rings is hard to find. The main concern I have come up with is the top ring clearance. I found this info on KB's site:United Engine and Machine Co..
Unless you can cross reference by individual ring gaps, you might be asking for trouble going outside of KB rings. I suppose it's possible to file the top ring of a different set, but it's not something I've tried or heard of with non file to fit rings.
So in this case, the safest course of action may be to just get these: Keith Black/KB Pistons 4000AM8-030 - Keith Black/KB Pistons Pistons & Piston Rings - Overview - SummitRacing.com. No telling what they are, probably overpriced cast rings. Sorry, not a fan of KB stuff and this isn't helping me become one.
  #75 (permalink)
Old 11-10-2009, 04:22 PM
yea i will just keep it simple and use the KB rings
Tags
302 , 350 , 4x4 , budget , build , building , drag , engine , f150 , ford , horsepower , hp , motor , street , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
