Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-17-2009, 04:14 PM
superv10's Avatar
superv10 superv10 is offline
Garage is empty, add now
superv10 is starting off with a positive reputation.
03 Navigator - interior lights don't turn off???
So, I have no idea what is up - the interior lights will not go off. Car running or not. The only way to get them off is to turn the rocker switch all the way until it clicks them off, but then there are no lights and all dash lights are on the dimmest setting... If you leave them off for a while then turn the rocker back on (about 10 minutes or so) they will not come back on as they should until a door is opened. Then voila!!! they stay on again... Anyone have any clue??
Is the switch bad? I've also noticed that the on-board computer display continuously shows a door open even though all doors have been verified closed...are they related and what would cause the open door issue?
Thanks all! This is our first Navigator!
__________________
-superPSD
2006 F-350
SD Lariat PSD 6.0 Fx4 LB, TorqShift, Nitto Grapplers, Spartan Tune w/Autometer Pyro, MBRP 4" Turbo back, Sinister EGR, Blue Spring, 08 Banjos, modded uppipe, ARP head studs, Red Cat-EC1 coolant, DieselSite Coolant filter
  #2 (permalink)
Old 09-17-2009, 04:19 PM
superv10's Avatar
Oops
Mod - please move my post - got it in wrong forum.
__________________
-superPSD
2006 F-350
  #3 (permalink)
Old 09-18-2009, 06:33 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Wrong forum or not, it you have a "door open" the interior lights will be on.
That's part of the courtesy light function. Had this problem on my '02 Explorer and it's the door sensors that are the problem. I think there's a contact on the little rod looking thingie that enters/exits the door edge at the hinge area. Cleaned them and the problem stopped.
-- Chuck
  #4 (permalink)
Old 09-19-2009, 06:57 AM
david_jr david_jr is offline
2008 Ford Expedition
david_jr is starting off with a positive reputation.
I had this problem on my 95 Windstar. Had to unplug the sensor on the offending door and that solved. Only problem is lights don't come on when the door is opened and no door adjar warning. Will work until you replace the bad sensor though.
Tags
2003, 2004, closed, courtesy, dont, doors, explorer, f350, ford, interior, light, lights, stay, truck, turn, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
