1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
08 F350 - no tow/haul
Old 09-16-2009, 11:08 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
the tow/haul feature appears not to work on my DRW. no light on the dash and no difference in behaviour I can tell..
anyone have a good debug process for this?
sam
Old 09-16-2009, 11:35 PM
SMok's Avatar
SMok
SMok is offline
I have a replaced the shifter assembly on a couple of super duty's to fix this problem. Haven't seen any other problems that causes this.
Old 09-17-2009, 07:12 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
is there a wire under the console which I can ground to test that the system works?
Sam
Old 09-17-2009, 02:11 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
Its the switch or the wires to the switch..
removing the upper steering wheel cover, unplugging the plug and jumpering across lights the light on the dash.. assume this will do the right thing at the computer too.
now to find the break.. but it looks like you have to pull the steering wheel to get to one tiny bolt holding the rubber boot cage. it would seem that the break should be outboard of the column itself as nothing can really move inside the column..
we'll see
Sam
Old 09-17-2009, 06:57 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
thanks to another post on an older truck concerning the wires, I pulled the shift lever this made it SO much easier to work on.. steps
1. removed top of column shroud (clips hold the two pieces together),
1a I also removed the 3 bolts holding the bottom piece to the column. to remove it completely you have to remove the one screw holding the adjuster arm to the column too.
2. removed 2 screws holding the column boot to housing
3. unhooked wire harness (tested for continuity to button, no good)
4. removed 1 star headed bolt holding stalk to
4a go to the shop with stalk in hand
5. the button is just sitting in the stalk, used a jewelers screwdriver to pry it out, and the wires slide up from the bottom..
6. cut the heat shrink off the wire bundle.
7. traced the failing wire,
8. used some very small bell wire, pushed it thru the bottom hole in the stalk up to the button end..
9. cut the bad wire, solder and some heat shrink..
10. same on the bottom end...
11. slid the botton back in the stalk, pulling the wires out the bottom,
12. used some electrical tape as shield on the remaining wire bundle
13. re-installed, stalk, connect harness. test (ignition on)
14. re-installed the top of the column shroud
sam
Bhildreth99
Testing.....
09-16-2016 07:55 PM
Jim McCann
10-14-2015 01:27 PM
KW7DSP
10-10-2015 01:58 PM
DesMoinesDieselDuty
04-25-2012 02:22 PM
ponyboy123
21
11-17-2008 08:11 AM
Quick Reply: 08 F350 - no tow/haul
