Rebuilt 300 inline 6 - Ford Truck Enthusiasts Forums
Old 09-16-2009, 10:08 PM
blueeyedfordguy's Avatar
blueeyedfordguy blueeyedfordguy is offline
blueeyedfordguy is starting off with a positive reputation.
Does anyone know where to get a reasonably priced, rebuilt 300 inline six with a carburetor? I checked jasper, and it is out of my price range. 1900$ or so. Road master has them for 1045$ with a 200$ core. I would like to get one in the future for this truck, or a older one. 1980-86 f150. Would this carb 300 6, bolt right onto my tranny? I have a 1988 f150 xlt lariat, with a 302, and a automatic overdrive tranny. Im am wondering about a well running engine perferably 1200$ or less, thanks for any help.
Old 09-17-2009, 06:50 AM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
Quote:
The only way UR going to be able to do it the way U wish, is to go to a Wrecking Yard & find a decent block, purchase a rebuild Kit & do it URself.
Any trans that fits the 240/300-289/302-351 blocks will work.
Old 09-17-2009, 01:05 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
I just saw an ad in the Pennysaver for a Ford 300 six cylinder engine. It says it has low miles and they only want $100. These are great engines and run forever. Call 916*504* 6730. Unfortunately, in the Sacramento area. Jag
Old 09-17-2009, 02:20 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
You might check with gofastparts.com. They are in Relands ca and carry just about every crate engine known- if they can't help you with a purchase they can probably point you in the right direction.
Old 09-17-2009, 08:42 PM
300 Buster's Avatar
300 Buster 300 Buster is offline
300 Buster is gaining momentum as a positive member of FTE.
I live in Mich. and have a '83 300 with 53k on it in my garage on the engine stand.If you want to call me we can talk about it.Buster 517-448-8245.
Old 09-18-2009, 11:23 AM
300 Buster's Avatar
I think you would be talkin about 250.00,I could tell you more,but I would be typing all day,just call and I can talk your ear off.
Old 09-19-2009, 01:21 PM
sounds great, but I can't afford the engine right at the moment. Thanks for the help though guys, I think I will keep the 302 in my truck, and put a carb., 300 inline 6 in a 1980 to a 1986 f150 with a four speed manual transmission, and more important four wheel drive, but im not 100% sure. Two wheel drive is great till december comes around. Then I have a 1/4 mile drive way to climb. I love a carbd 300 6 and a four speed better for certian things. But for right now This 302 2wd is great for hauling, and driving around. Really, thanks for your help. I will let you know when I get a job, again and get everything back together. ONly been unemployed for a short while.
Old 09-23-2009, 09:03 PM
greyghost85's Avatar
greyghost85 greyghost85 is offline
greyghost85 has a good reputation on FTE.greyghost85 has a good reputation on FTE.
dang, 300 buster, why couldn't you live in missouri.
Old 09-23-2009, 11:22 PM
300 Buster's Avatar
Yes,greyghost85,ain't that the way it always turns out? The best deals on things that are too big to send are always too far away.
Old 09-23-2009, 11:30 PM
yep....but ya caint give up. persistence pays off.
Old 09-23-2009, 11:34 PM
300, what kind of truck do you have, and why do you have a I6 sittin around?
Old 09-24-2009, 11:25 AM
300 Buster's Avatar
I guess I signed off too quick greyghost85.I have a '96 f150 300 5 speed with 163k.I had a '91 F150 300 and I bought a '83 f150 that had been rolled up on its side in a wreck,body was pretty messed up but the engine was in great shape with 53k on it.So,I pulled the engine and pulled the oil pan,put in a new Melling oil pump and put an EFI valve cover on it and derusted the pan and cleaned the engine and painted it Ford blue.It has the manifold assy with carb sitting beside it and also the crank pulley dampener,they were removed for convertion to an EFI,also gave the dizzy to my nephew,since I would have used the '91 dizzy.This was all for a back-up engine for my '91,which has long since departed.Since I have found out that the head has the wrong combustion chambers for EFI.I may do something with it down the road,I thought I would help this young man out,but he's short of funds and really doesn't know what he's going to run yet.I put you on my friends list,then I couldn't get back to the part if I would accept your request.If you send it again I'll fill it in first.I'm pretty new to this forum stuff and really don't know how every thing works.
Old 09-24-2009, 12:15 PM
i was new at the forum stuff too, but as you monkey with it, you pick it up.
Advice on making my engine more powerful Kregj 1987 - 1996 F150 & Larger F-Series Trucks 27 08-03-2014 03:15 AM
300I6 w/c4 in 58 f100 Henryj1010 Ford Inline Six, 200, 250, 4.9L / 300 2 06-24-2011 08:21 PM
Transmission problems can you help? specops12 1987 - 1996 F150 & Larger F-Series Trucks 2 05-17-2011 09:48 PM
1988 300 inline 6 swap bcallahan 1987 - 1996 F150 & Larger F-Series Trucks 4 02-16-2009 09:47 PM
1976 inline 300 swap in 1959 f100 rodriguezfords Ford Inline Six, 200, 250, 4.9L / 300 1 03-22-2008 08:31 AM
Tags
1986, 300, automatic, blocks, buy, crate, engine, engines, f150, ford, inline, problems, trans, trucks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
