Quote:
Originally Posted by chris tatro
i recently bought a 1961 econoline van for 200 bucks. need help decoding the vin
E10SH191740
WB 090
COLOR A
MODEL E104 ??
DATE (IS BLANK?)
TRANS A
AXLE 02
79HP@4000RPM
Welcome to FTE
E10 = E100
S = 144 1V 1-6
H = Lorain OH Assembly Plant
191740 = 1961, assembled July 1961.
90" Wheelbase
A = Raven Black
E104 = Incorrect, should be
E140 = Econoline Van
A = Ford 3 Speed Light Duty Manual Transmission
02 = Ford 7" Rear Axle / 4.00-1 / non Limited Slip / 2300 lb. Rear Axle Capacity.
79
net HP @ 4,000 RPM
** E104 is a pickup. If the MODEL code
does show E104, the left door has been changed, which means some/all of this info is in-correct.
What happened was: The original left door was damaged, and replaced with a used door from a pickup.
When this occured, whoever did this...forget to install the original Warranty Plate on the replaced door.
