1979 f250 supercab 4x4
Old 09-16-2009, 05:37 PM
jtapal's Avatar
jtapal
jtapal is offline
Hey, does anyone know if all of the 1979 f250 supercabs came with the threaded inserts for the optional pop-out windows? My truck has them and I was wondering if mine ever had the pop out windows.
Old 09-16-2009, 06:34 PM
ranger429's Avatar
ranger429
ranger429 is offline
The rear side windows? No, pop out windows were an option and were not stock on all supercabs.
Old 09-17-2009, 09:41 AM
jtapal's Avatar
jtapal
jtapal is offline
Thanks, but I think at one time my truck had the pop out windows and one of the previous owners replaced them with the standard ones. ( I found some of the pop out ones in a junk yard and when I took a look at how I was going to mount them I noticed that the paint was brighter than the rest of the cab in the exact shape of the latch that mounts to your cab.) I need to find someone with a 1973-1979 Custom Supercab to tell me if their truck has the threaded inserts.
Old 09-17-2009, 09:48 AM
ranger429's Avatar
ranger429
I guess I misread your post. I thought you were asking if pop out windows were stock. I buzzed right past the threaded inserts part.
Old 09-17-2009, 10:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
D4TZ10302A02A .. Retainer, Quarter Window Latch.
While Ford calls this a retainer, it's actually a threaded shouldered insert with a round head.
One of these per side.
D4TZ10302A06A .. Spacer, Use with the above (2 of these parts per side).
The insert fits through these two spacers, then through the following:
D2FZ7330212A .. Insert, Use with the above (1 per side).
What you need to see is the following;
1973/79 Ford Light Truck Parts Catalog // Body Illustration Section 200, Page 13.
The entire movable quarter window is shown with all the attaching parts.
FTE member jermafenser has this catalog on a CD, can scan and post this illustration.
You can get your own catalog, as it's available from hipoparts.com for around 25 bucks.
btw: Supercabs were introduced in 1974.
Old 09-17-2009, 11:35 AM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
Old 09-17-2009, 02:10 PM
jtapal's Avatar
jtapal
jtapal is offline
Hey thanks alot for the diagrams. Those also help because when I took the windows out of the junkyard I broke the plastic hindges now I've got a part number on them. I got the windows and latches $45.00!
Old 09-18-2009, 08:43 AM
NumberDummy
Hey thanks alot for the diagrams. Those also help because when I took the windows out of the junkyard I broke the plastic hinges now I've got a part number on them. I got the windows and latches $45.00!
The parts catalog illustration (diagram) only shows partial part numbers.
Compare the three part numbers I typed in post #5 to the basic part numbers shown in the above illustration.
Is this what you broke? =
D5FZ73303A12A .. Quarter Window Hinge Retainer-Plastic. Shown as 303A12 in the above illustration.
Note: These are not the same parts as D2FZ7330212A.
All these parts are Obsolete = No longer available from Ford.
D5FZ73302A12A = GREEN SALES CO. in Cincinnati has ONE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any, but...
These same hinge retainers were also used on the quarter windows of 1972/80 Pinto & Mercury Bobcat station wagons.
Old 09-18-2009, 02:25 PM
jtapal's Avatar
jtapal
jtapal is offline
Thanks, but what I broke is shown as 302A12. when I pulled the windows form the junkyard the plastic was sun rotted, there wasn't much I could do. Do I just need to go to a glass shop and see if they have a way to mount these windows or do you know of where I can order some these retainers from?
Old 07-29-2014, 07:43 PM
Jchet729's Avatar
Jchet729
Jchet729 is offline
Just adding this to my list
vortec 1
1999 to 2016 Super Duty
536
11-28-2018 10:44 AM
1977F250XLT
WTB - Ford Trucks & other vehicles
11-17-2016 06:58 PM
86F250HDSO
Ontario Chapter
17
03-18-2016 07:00 PM
redman84
17
05-29-2013 12:38 PM
ten.mile
12-11-2012 05:56 PM
Quick Reply: 1979 f250 supercab 4x4
