what transfer case was used in 76?
I'm collecting parts to do a 2wd to 4wd conversion. I've found what the guy lists as a "203 or 205" divorced transfer case. I want to ****** it up because it's the first divorced case I've found. Is this the typical transfer case for the mid 70's? Thanks
the f250's used both in a divorced/remote mount, either a 203 for a full time 4wd setup (non locking hubs)
or the 205 for a part time 4wd system (with locking hubs)
i personally would rather have the 205 as its a gear drive design & has been proven to be nearly bulletproof & the 203 is chain driven & problematic
How do I tell if it's a 203 or 205? Is there a tag on it and if the tags gone how else would I tell? I definetly don't want the 203 if it's all time 4x4. The seller isn't sure which one it is but the axle he's selling with it has manual locking hubs, so if they came from the same vehicle it should be a 205, but who knows. He does know that it is divorced which is perfect because I can use my tranny.
there should be a tag on the frt side of the case & it will tell you whether its a 203 or 205
the 203 is somewhat bigger than the 205 & has a large cast iron center differential on the back side of the transfer case
the shift patterns are also different
203:
hi-loc
hi
n
lo
lo-loc
205:
4wd hi
2wd
n
4wd lo
im no expert on the 203 but its possible that it has been converted to part time this could be why the frt axle has locking hubs
203:
hi-loc
hi
n
lo
lo-loc
205:
4wd hi
2wd
n
4wd lo
on
1 Post
203:
hi-loc
hi
n
lo
lo-loc
205:
4wd hi
2wd
n
4wd lo
203:
hi-loc
hi
n
lo
lo-loc
205:
4wd hi
2wd
n
4wd lo
4lo
N
2hi
4hi
just so there is no confusion.
Lets not dismiss the possibiliy of a part time converted 203. The shift pattern will be different and because of the 2wd function, this can be mistaken for a part time case.
This a Np 203 case. notice the huge tail section and housing. This is where the differential for the case is located:
This is a Np 205. See thow small the tail section is. This does not have a differential inside. This case is very small compared to the 203:
Yes, each case has a blue tag attached to each case. Most are under years of dirt and grime.
No argument here. I know that your answer was correct for the year and the question. I just could not remember the last thread when this came up.
Ehhh, only a few days ago, and I cant remeber it. I probably should not have eaten so much paste as a kid...........
I remember talking about it, I don't remember where. Somewhere, somewhere... don't eat the paste, young Wiggum!
203:
hi-loc
hi
n
lo
lo-loc
205:
4wd hi
2wd
n
4wd lo
203:
hi-loc
hi
n
lo
lo-loc
205:
4wd hi
2wd
n
4wd lo
I have a 76 f250 with a bad 203 full time can i direct swap a 205 into it without any mods? I can get a 205 for 150 bucks were as a 203 is 500 bucks at local junkyard I dont want full time i plan to swap hubs and make it part time it is a divorced t case
I believe the crossmember is the same however the brackets that attach the transfer case to the crossmember they are different .. So you'll need a set of brackets for a divorced NP205 .. I may have them if you can't find them .. $150 for a divorced NP205 is a great price maybe he has the brackets too ..
Jkenosh
09-26-2015 07:39 AM
rakent
02-21-2010 05:16 PM
OpieCunningham
23
10-25-2009 11:10 PM
