Cold air intakes. Worth the money?
Old 09-15-2009, 09:01 PM
btorear's Avatar
btorear
btorear is offline
Hello. I have an 89 f 150 with a 4.6L inline 6. Thinking about one of those K&N cold air intakes, but wow are they expensive. Any opinions on the advantages vs cost?
Old 09-15-2009, 09:12 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
I've quite often heard that the 300 I6 and 460s come with better stock airbox systems than aftermarket "cold"(warm underhood air) intakes. If I were you, I'd stick to the stock setup.
quicklook2's Avatar
quicklook2
quicklook2 is offline
get a good complete tuneup with motorcraft parts.
that would help more.
the stock set up is just fine.
Old 09-15-2009, 09:28 PM
RJG1987's Avatar
RJG1987
RJG1987 is offline
i feel that way more and more everyday, good call
Old 09-15-2009, 09:38 PM
skaterbro's Avatar
skaterbro
skaterbro is offline
You already have the inlet tube that 302/351 guys look for. Keep it stock and do what Quicklook said.
btw, can i have your inlet tube.
Old 09-15-2009, 11:08 PM
crestfallinman's Avatar
crestfallinman
crestfallinman is offline
yeah stick with what u got, i have a drop in k&n filter and love it, and plus if u put the whole k&n setup you will be drawling warm air in
on top of that the 300 makes its power at such low rpm's that a cold air intake (which usually helps higher rpm's) would be pretty pointless
Old 09-16-2009, 12:36 AM
deerslayer joe's Avatar
deerslayer joe
deerslayer joe is offline
Quote from skater bro: "You already have the inlet tube that 302/351 guys look for"
i got a 351 im lookin to boost the power, at least the low end of er, and i can get a 300 inlet tube for dirt cheap. how do i convert one of them 300 i6 inlet tubes to fit my truck? or do i just replace mine w/ the ones off a 300?
Old 09-16-2009, 08:55 AM
btorear's Avatar
btorear
btorear is offline
Thanks for all the info guys. Really appreciate it.
Old 09-16-2009, 09:09 AM
quicklook2's Avatar
quicklook2
get the inlet and it goes right on with no cutting or anything.
Old 09-17-2009, 03:11 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I agree the I6/460 tube is the way to go.
Adding a better flowing filter is also a good idea.
The CAI is a joke, no matter who made it. I don't know why they are called cold air intakes anyway, since they suck in warm air from under the hood. I had one and it was worthless except for sounding cool. My truck didn't run as good and got worse fuel economy.
Old 09-17-2009, 03:15 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Just a bit of a thought provoker, is there anyway a guy could take the 300 I6/460 intake and make it better and/or replace it with a newly plumbed system in the same place?
Old 09-17-2009, 03:18 PM
quicklook2's Avatar
quicklook2
no real benefit to doing this.
Old 09-17-2009, 03:48 PM
bigmacmonday's Avatar
bigmacmonday
bigmacmonday is offline
question, is there a benefit to taking out those cone plastic things in the 460 air intake tubes? I was told it is good to cut them out so i did and if it did anything it gave me less HP instead of more.
Old 09-17-2009, 03:56 PM
Dodge-My-Cummins's Avatar
Dodge-My-Cummins
Dodge-My-Cummins is offline
so i have access to an intake tube and box from a 92 300I6 truck for $10 ....
Its a little bit of an upgrade on a 93 F150 302 ?? just the tube that goes from the throttle body to the box ?? or the box too
thanks
Old 09-17-2009, 04:20 PM
skaterbro's Avatar
skaterbro
No, you want just the inlet tube. It draws fresh air from behind the grill and sends it to the airbox.
Quick Reply: Cold air intakes. Worth the money?
