Overdrive light on shifter is flashing
Thanks...kinda
Thanks guys even tho that is sooo far from what i wanted to hear. Yes it's a 7.3 and it has 159000 miles on it and its been sittin for almost 2 yrs bc i lost my lisence. I havent had the first bit of problems out of it until now...right bf i get to start drivin again of course. I have a programmer on it that pulls codes and i tried that and nothing came up. Could the programmer be the problem?
The tranny was NOT built to take the kind of abuse meted out by a chipped engine. If you're gonna play, you're gonna pay.
Now that I'm off of my righteous rant, I have some useful advice. I think. Neither your programmer, or most OBD-II scan tools, will read transmission codes. Has to be accessed by a transmission compatible scan tool. The kind your local Ford dealer has.
Some, such as Autotap and AutoXray can have the capabilities of reading enhanced codes, but I'm not completely sure if it'll see your problem. Mark K will likely have some input here...
Normally I would agree concerning replacing parts but in this case, and because differential speed sensors have a habit of going bad, a replacement Motorcraft sensor runs $35 on the internet. That's less than what a dealer would charge for a code read. If the sensor is not the problem then it's off to the dealer or a trans specialty shop.
You have a point there about cost. However I don't think we have enough information. The OP didn't mention how the truck is driving. If it seems to be driving fine you likely have a good idea. However, with the tuner he's running as well as the miles on the truck, I think it's likely there's something wrong internal.
To the OP:
How does it drive?
To the OP:
How does it drive?
Driving
It drives fine for the most part except for the torquing up and the driveshaft finally catching up and banging due to the u-joints being worn and hanger berring being shot. I have half the driveshaft out now to replace the u-joints but the bolts that hold the hanger berring in are stuck and i dont have a 16pt socket to get the bolt out of the side that bolt it to the transfer case. Therefore, the second half of the driveshaft is still in the truck. This mess is driving me crazy.
