Kingpin or Ball and Joint on F-250 Diesel series? - Ford Truck Enthusiasts Forums
Old 09-15-2009, 02:00 AM
TheFixer TheFixer is offline
TheFixer is starting off with a positive reputation.
This is what I have:
1987 Ford F-250 Diesel... 2 wheel drive...
I've been running into a problem. I hope I have the terminology correct (been doing a lot of reading today).
The Chilton's manual for this truck says all 2 wheel drive models have an upper and lower ball joint on the front wheels connecting the spindle assemblies to the front axles.
However I am pretty sure that is NOT what I have. Everything else in the manual's diagrams looks the same. Radius arm, twin I-beam front axles, springs, tie-rod, etc. all look the same in the manual as what is on my truck.
However the spindle assemblies are attached to the twin I-beam axles using kingpins (I think that is what it is called, correct me if I am wrong) and not ball joints...
I thought maybe the Chiltonís manual is incorrect and left out some info, however I have not even been able to find parts online for kingpin assemblies. The Ford dealership in my area is closed at the moment and I can not call them.
Has anyone seen kingpin steering on a 1987 F-250 before? Did the Chiltonís manual just leave out some info? I am kinda worried cause when I tried looking up parts for this online I couldnít find anything about replacement parts for a kingpin.
Any help or advice would be greatly appreciated.
BTW the original problem I have is the wheel on the passenger side. There is a VERY LOUD grinding noise when steering coming from the passenger side. I put the truck on jack stands and removed the tie-rods and I can easily move the driver wheel along the steering axis by hand. However the passenger side wonít budge.
Thanks in advance.
Old 09-15-2009, 05:37 AM
79f150toy's Avatar
79f150toy 79f150toy is offline
79f150toy is gaining momentum as a positive member of FTE.
While you may have the twin I beam suspension, its probable that the knuckle is attached to the I beams by ball joints....go look at your truck and see what you have... look at autozones website and see if your trucks has ball joints-you will see the two large nuts holding the knuckle onto the I beam...a king pin will be just a large pin that goes through the I beam which has a notch cut in it to hold it in place....look at these kingpins... http://www.autozone.com/autozone/cat...&parentId=46-0
these king pins has a screw-in cap with a grease fitting to keep junk out...
Old 09-15-2009, 07:41 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
If it is a F350 4x4 it has king pins. If it is anything else it has ball joints
Old 09-15-2009, 08:59 AM
472SCJ 472SCJ is offline
472SCJ is starting off with a positive reputation.
it might be possible if your 87 is a early production truck(1 / 2 / 3 / of 87 ),if could have been fitted with leftover 86 kingpin I beams
Old 09-15-2009, 04:32 PM
Here is a picture of the back of the spindle.
I do not see any ball joints. There are just two caps with grease plugs, one of top and and one of bottom.
Old 09-15-2009, 05:33 PM
That is a king pin
Old 09-15-2009, 05:44 PM
Quote:
Originally Posted by Diesel_Brad View Post
That is a king pin
That was what I was thinking.
I definitely have a 1987 F-250... I thought maybe the vehicle registration was wrong on the year model. So I typed the VIN number into a ford website and it confirms it is definitely a 1987 model...
Now how the hell am I supposed to get parts for this thing?
Old 09-15-2009, 05:47 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Ford strikes again.
Just tell them you have a 1986 2wd F-250 and need kingpins for it.
Old 09-15-2009, 06:18 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
Is it just "tight" at the bushings due to lack of maintenance? if so you might be able to free it back up without tearing it all apart. I've done a few of them over the years.
Will it take grease? doubt it will, can't quite push that grease gun handle down huh, can't force any new in?
Heating those bushings up with a torch, just as hot as you can but without melting or burning the dust boots mind ya, don't need to be red hot, no where near it. Softens the old hardened grease you can usually get them to take new grease without to much effort. Once they take some new grease forcing the old stuff out, top and bottom bushing, they useally start moving much easer. Just a little at first then nicely once things get moving again.
The bearing in there is another story though, if its shot nothing will help but a new pin and bearing. The weight of the truck sits on those and if its shot it won't improve much if at all. Good news is that bearing is rarely the problem with stiff king pins.
Kingpins and Tie rods for 1965 F100 F1Hunter 1961 - 1966 F-100 & Larger F-Series Trucks 12 01-29-2016 01:11 PM
1980 f150 2wd spindle mounted bushings 44nneedit 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 01-29-2016 11:54 AM
Looking for a front spindle for possibly 1964 Econoline van kamikazzi 1961 - 1966 F-100 & Larger F-Series Trucks 6 06-10-2007 07:02 PM
Twin-I-Beam Suspension for 48-52 F-2/3 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-01-2006 07:32 PM
I know this is the wrong forum but..... BigBrownTruck Ranchero & 1961 - 1967 Econoline 3 05-08-2000 07:53 PM
Tags
05, 1987, 4x4, ball, f150, f250, ford, front, ibeam, joints, king, kingpin, knuckles, pin, pins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
