5.0/5.8 performance upgrades - Ford Truck Enthusiasts Forums
Old 09-15-2009, 01:29 AM
97FRD1TN's Avatar
97FRD1TN 97FRD1TN is offline
97FRD1TN is starting off with a positive reputation.
Hey everybody i'm sure I can speak for a lot of of ford fans when I say I am looking for more power out of my truck so I was just curious if anyone has installed any major aftermarket parts on their efi ford trucks ie aluminum heads,roller rockers and an intake,in primarily stock form like pistons and camshaft.I am considering putting on edelbrock heads part #350-60289,1.7 roller rockers and the edelbrock truck intake.My motor is stock and runs good so i would like to keep it that way,I just want more power and this to me seems like the cheapest way,it seems like this combo would be cheaper than spending the 4000 grand or so to put on a supercharger which is gonna give me like 70 horse and then i gotta get bigger injectors,mess with the timing etc.So I guess what I am wanting to know is how easy would it be to put the heads,rockers and intake on and will I run into any serious problems like having to get longer pushrods or anything else,or would it just be easier to put on a supercharger?Like I said I would like to keep my engine stock except for the mods so no flat top or domed pistons just the stockers with whatever compression I gain from the heads.Also does anyone have a supercharger on their trucks if so was it worth it?Sorry for being so long,any advice would be greatly appreciated.
Old 09-15-2009, 08:23 AM
94f250HD's Avatar
94f250HD 94f250HD is offline
94f250HD is starting off with a positive reputation.
I can't comment on the heads as I haven't done it. But I will mention that the first thing you might want to do is open up the exhaust and Intake sides of things if not already. Then you might want to just try a CAM swap. Bang for the buck I think that is the best way to go with the least amount of work and if you decide to do more you will need the exhaust opened anyway.
The other two options of doing the heads and or supercharger you might want to rebuild the motor first unless you have super low miles. With the heads you might as well since you are 80% of the way there anyway and I wouldn't supercharge a stock motor with allot of miles.
Old 09-15-2009, 10:11 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
What motor do you have and what year is the truck?
The Edelbrock stuff is equally overpriced for what it delivers on a stock bottom end, the very first things that should be upgraded on these trucks are the exhaust and cam.. especially if you have a 5.8. For the most part changing the intake is a waste of $$ though heads are a good idea with the 5.8 as well. BUT.. the sum of all the changes has to stay within the limits of the stock EFI system(~300hp) and that is actually pretty easy to reach. That is unless you have a mass air truck which will tolerate more or you have emissions tests to worry about, then you may have to scale back your goals somewhat.
Old 09-15-2009, 03:39 PM
97FRD1TN's Avatar
the truck is a 97 with a 5.8 and it is speed density.So I would presume I can't put in to radical of a cam.This next question is for conaski as I take you for someone who knows their fords.What is a good set of heads that is cheap,not necessarily aluminum that flow good make power and are set up for pedestal mount rockers?Also how radical can I go on a cam without having to change to mass air because i really don't wanna do that,and emissions are not a problem.?I don't need a lopey idle just looking to get about 50 to 75 more horsepower?
Old 09-15-2009, 05:34 PM
Conanski's Avatar
Quote:
Originally Posted by 97FRD1TN View Post
the truck is a 97 with a 5.8 and it is speed density.I don't need a lopey idle just looking to get about 50 to 75 more horsepower?
You don't even need heads for that, just replace the whole exhaust with headers and whatever you like behind it and find a used HO roller cam and add 1.7 rockers or get the Comp 35-349-8 and use the stock rockers.
Old 09-16-2009, 01:53 AM
97FRD1TN's Avatar
well i already have headers and true duals without cats,so i'm good there.so rockers and a cam will help it out that much?
1996 5.8l roller engine questions Pat54632 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 40 02-23-2017 09:49 AM
1987 351w 4 barrel swap to svo aluminum heads or rebuild stock heads autox65 1987 - 1996 F150 & Larger F-Series Trucks 3 01-12-2017 12:09 AM
Help decide for 351 budget build Redneckfordf2502002 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 9 04-06-2016 12:10 PM
Cant keep 408w together!! now the crank broke. FarmerFrank Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 11-21-2012 08:53 PM
want to hop up my 351m a little iceman320 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 09-08-2010 06:45 PM
Tags
1990, 50, 58, 97frd1tn, camshaft, edelbrock, efi, f150, ford, idle, lopey, package, performance, power, truck, upgrades
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
