How much can this truck tow?
I have a 96 F350 Regular Cab LB 4x4 with a 460/c6 combo and would love to make the leap to the diesel world. I really don't want to take out another loan to buy a PSD. I found a 1991 F350 Crew Cab 4x4 with the 7.3idi/E4OD and I was wondering if any of you have similar setups like this and how much can do you tow with it STOCK. By stock I mean no more than the basics like intake and exhaust mods. I want something cheap and easy to work on if a problem should arise. I can do extensive vehicle work and mods, I just don't want to deal with it with another kid on the way. I need a powerful, reliable truck with more than just one bench seat. Thats actually the main reason why I want a new(to me) truck. Since I need a new one, it might as well be a diesel. Either find a truck with the 7.3idi or end up putting a ZF5 in my 96 for better mileage and only take part of my family with me when I go places.
Those of you who respond, please include your axle ratio as well so I know what setup you have and what I should look for. I need it to tow 10,000lbs. on occasion.
I'd find an IDI with a turbo on it already. It will get the job done, not as fast as a PSD but it will get you there. I have pulled 9600lbs with my truck without any problems. I may have pulled more, but couldn't say for sure. I have 4:10 gears with 33" tires. The best part is, my IDI with a load gets the same mpg my 460 does empty.
if you find one with a factory turbo and put the ats upgraded housing and downpipe on it will eat any 1st gen psd.but even without the turbo it will pull anything you want it to,it may not be the fastest to get there but will hands down be the most durable.someone will light me up for saying this but if my idi goes i might be dropping a 12 valve cummins in.......but the idi is most definatly my favorite of all time.
I am not looking for a turbo 7.3idi. The truck I am inquiring about is a 1991 7.3idi non-turbo. I don't really want a turbo equipped truck. I just want the trusty old 7.3 in a truck with a roomy cab. That is the truck I would like to get feedback about. I am not looking for the most possible power. In fact, if a good crew cab 6.9 truck comes along I will probably buy it if the price is right. Do any of you guys tow with a stock 7.3idi non-turbo?
Hoooeee! That's about double what the truck is rated for! I've towed more than that but they were grain trailers with SMV placards and I didn't go above 25 mph. I used to travel with an overhead camper plus a 30 foot Terry Manor trailer loaded for a long trip, tipping the scales at almost 19K (whichis more than rated). Even with a Banks kit and a built pump, my truck was workin' big time just to accelerate on level ground, let along getting over the Rockies, the Sierra, the Appalachian and every other mountain range we crossed back then. Wow, 32K... that's scary, man!
mine is an 87 6.9 all stock except for 3" from the y back, t-19 4sp man, 3.55 rear extended cab(the one in my avatar) towing a bumper pull lowboy w. 4k mine works to build up speed, but with a 13K 5-er tarvel trailer it will roll on with no problems. i get about 17 empty and with the 4k load on reciever hitch. havent gone more than 30 miles or so with the 5-er. have also put a little over 8k of rock directly in the bed. squashed the tires, had the springs mashed good too, but when i came off the material yard where i worked, i never looked back getting up with the traffic.
