add bags or a leaf
I'd like to hear that too. Had Airlift bags on a '90 F150 to support a camper for 10+ years and never had occasion to wish for individual air pressures.
I had the Airlift compressor setup. When the Airlift pump died I replaced it with a generic 12v compressor. When that died I went manual until the bags gave out. 15+ years old at that point so I didn't mind.
If the air lines are tied together, you eliminate the "counter-sway" and leveling capabilities of air bags. When they're tied together, and loaded heavy, and go around a corner, the compression of the bag on the one side will force air into the other bag with less weight on it, exaggerating the lean. Same thing with an uneven load, the air is going to move from the bag you need it in, to the other, and again, exaggerating the uneven condition.
I have my rear bags separate. My fronts are tied together. I need the rears separate for sway control, but the front end I need to articulate more for plowing uneven surfaces.
Okay, I see how the leaning issue makes sense. I suppose that would be critical with high center of gravity loads like a slide-in camper.
With a 5th wheel or gooseneck, where the balance of the load is isolated from the truck, it probably doesn't make any difference if the lines are Tee'd. Because the hitch swivels. In fact, in the case of a bag or line failure, it would probably be better if the whole truck dropped equally.
I carry a big spreader in the back of the F350, along with 1.5-2 tons of salt. When I leave the yard, she's generally real close to, or over GVWR. Also, due to the nature of the spreader, more than 1/2 the weight is behind the rear axle, so it's bearing the entire weight of the load. It's not especially top-heavy, but it's heavy none-the-less. But before installing the bags, the truck was downright scary around corners. For towing, I don't see any downsides to having the rears separate (other than like you said, a failure, in which case you could just as easily deflate the other side), but I dont see any advantages to having them together either. I'd still separate them, unless the truck already has a supstantial sway bar in the rear, then in may not matter anyway.
As for the front, the weight of the plow is evenly distributed across the front. The Blizzard plows also don't articulate as well as some of the other brands, so having them tied together helps the front axle articulate better over uneven surfaces than if they were separate..
My truck had a rear anti-sway bar and heavy add-a-leafs. Those would obviate the need for additional sway control. I did not feel any difference after I went to manual fill with a T.
The Airlift kit circa '91 had (approx) 1/4" lines. Can't see much side-to-side flow there. Maybe couple of pounds during a turn event?
But even 2 lbs flow would make a 4 lb difference ie (60/60 --> 58/62) so if sway is a problem then don't T.
I've got a sway bar and overload springs on my truck, and as I mentioned, the sway is noticeable at first after adding the inboard air bags. My kit did come with a "T", but I didn't install it.
rmoritz1
10-31-2007 07:09 PM
