1998 ford f150 no voltage to fuel pump - Ford Truck Enthusiasts Forums
Old 09-14-2009, 03:22 PM
inkmanj inkmanj is offline
inkmanj is starting off with a positive reputation.
have replaced fuel pump relay,checked shutoff under dash,checked fuselink,??????????????
Old 09-15-2009, 08:03 PM
DarkNite's Avatar
DarkNite DarkNite is offline
DarkNite is starting off with a positive reputation.
Quote:
Where is your fuel pump relay?
Im in the same boat. Mines a 91 F150 and their is no power to the fuel pump. Im thinking its my EEC (computer) but want to replace the relay 1st.
Old 09-15-2009, 09:25 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
DarkNite,
The relays:
Old 09-16-2009, 09:30 AM
DarkNite's Avatar
Subford, THANK YOU!!!!!!!!!!!!!!!!!!!!!!
Old 09-19-2009, 06:07 PM
turbolaser turbolaser is offline
turbolaser is starting off with a positive reputation.
I just had same problem with my 87 f250. If the relay does not fix it start check wires for proper voltage before you replace the eec. I had a corroded wire in my wire harness that was only allowing 3 volts to get thru instead of the 12 volts that it should of had. It took me about 3 hours of traceing wires, testing with meter and unwrapping electrical tape from the harness but i found it. Cut out the bad spot and soldered in new wire and now i have power to the pump again. Always test before buying electical parts, since they can'nt always be returned if it did not fix the problem.
Old 09-19-2009, 09:17 PM
DarkNite's Avatar
Quote:
I replaced the Fuel pump relay and it fired right up...went to bolt the bracket back up and it shut off. Got to playing around with it and it seems to be the connection to the EEC relay. So Im going to replace that and see if it fixes it.
Old 09-30-2009, 10:57 PM
ksmith3838 ksmith3838 is offline
ksmith3838 is starting off with a positive reputation.
so my 92 f150.. relay not kicking on.. where is the EEC module?? thanks
Old 10-01-2009, 07:42 AM
subford's Avatar
Quote:
Your PCM is behind the drivers kick panel.
Old 10-01-2009, 08:36 AM
kc0rey kc0rey is offline
kc0rey is starting off with a positive reputation.
Check the fusible links to the relays. Fuel pump relay and the EEC Relay.
Old 10-01-2009, 08:48 AM
subford's Avatar
Quote:
The only fusible links on a 92 are for the alternator and main power. If the main power fusible links are open the truck would be dead with no power to anything.
He might want to check all the fuse in the engine compartment fuse/relay box.
Old 10-01-2009, 08:53 AM
subford's Avatar
See thread:
http://www.ford-trucks.com/forums/88...not-start.html
Old 10-01-2009, 11:13 PM
Quote:
Nope not there... neighbor said he thought it was behind the ash tray... according to electrical drawing it should have like 48 wires on it... just not sure what it looks like... thanks..
Old 10-01-2009, 11:38 PM
Yes, it is. If you truck is stock.
Look at the firewall side. You'll see the connector. The EEC is on the other side of the firewall. You'll also see a bracket that holds it in. There is one bolt at the top, remove that bolt and slide it into the inner fender well. our gonna have to be creative, you can remove the computer with-out removing the inner fender well. My brother did and he's not too bright so, I am sure you can do it.
Old 10-01-2009, 11:55 PM
Jeez...no wonder I am confused. You are one of 3 posters in this thread with the same questions, and 3 different trucks. Go post your own thread and quit crapping in this one. When you do this is really screws stuff up.
Old 10-02-2009, 01:36 AM
1988F-150 1988F-150 is offline
1988F-150 is starting off with a positive reputation.
The fuel pumps on my '88 did the same. Both fuel pump wires had corroded out of the EEC connector or whatever it was. The EEC thing above the wheel well. I'd check every connector you can think of and find in wiring diagrams before you go replacing things. You'll spend more money than need to and be one pissy panda.
fuel pump problems LjH 1987 - 1996 F150 & Larger F-Series Trucks 4 05-12-2015 02:18 PM
87 F250 Fuel delivery trouble sapman92 1987 - 1996 F150 & Larger F-Series Trucks 0 09-07-2014 03:55 PM
Fuel Delivery Module SiscoKid 1987 - 1996 F150 & Larger F-Series Trucks 2 03-14-2013 06:37 PM
no power at fuel pump Ed_B1 1978 - 1996 Big Bronco 15 07-14-2011 07:39 PM
98 F150 cranks but won't start b4pjoe 1997 - 2003 F150 8 09-10-2009 02:20 PM
Tags
150, 1987, 1991, 1996, 1998, coming, f150, filter, ford, fuel, pump, relay, truck, volatage, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
