Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-14-2009, 11:02 AM
thinksnow thinksnow is offline
Garage is empty, add now
thinksnow is starting off with a positive reputation.
Rear view mirror
I found a distributor of Gentex products so Im going to install the factory monitor mirror / 3rd brake light camera. In looking at our Expy the mirror has a wire plugged into the back of it. Im assuming this wire is for the auto headlights??? I know the Gentex monitor mirror also has a wire that plugs into it. However there is also a plastic box about 2"x2" and 3/4" thick behind the mirror. At first I thought this box was for the satelite radio but there is an antenna for that on the roof. Does anyone know what this plastic box is for?
  #2 (permalink)
Old 09-14-2009, 11:27 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
It's for the compass.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 09-14-2009, 11:28 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
wires to the mirror itself are for the Camera Monitor (if installed) and the auto-dim power wire
wires to that little black box are for the compass
there is a little black sensor on the dash. that is the Auto Lights sensor.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 09-14-2009, 11:41 AM
So is my truck already prewired for the camera? I didn't think it was available until '08. I guess I could always take off the 3rd brake light and see if the is a connection for the camera there.
  #5 (permalink)
Old 09-14-2009, 12:45 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
The camera is not in the 3rd brakelight. it is over the lic plate where the lights for the plate are.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
  #6 (permalink)
Old 09-14-2009, 12:51 PM
I didn't realize that. The Gentex distributor has one that replaces your 3rd brake light. The mirror/ monitor comes with a 6 ft cable that runs down the pilar to under the dash and a 20ft cable the runs back to the camera. Gentex is the company that is contracted with ford for their factory system.
  #7 (permalink)
Old 09-14-2009, 07:37 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
3rd brake light would be very odd. . .your image would be very wide unless it has an abnormal lens.
  #8 (permalink)
Old 09-20-2009, 09:36 PM
TIKT B8 TIKT B8 is offline
TIKT B8 is starting off with a positive reputation.
I really want to add a camera to my 07 as well and looked at the gentex cameras, but was not sure of the actual camera route. Does gentex sell a kit? What is the price range?
__________________
2007 Expedition Limited White Sand
  #9 (permalink)
Old 09-21-2009, 08:03 AM
I found this site that carries Gentex equipment, there are other site out there though. They have the mirror/monitor like the one that comes from the factory. This mirror has a 2.4" display for the monitor. I believe there is a bigger one available, I think it has a 3.5" monitor. They also carry the 3rd brake light with the camera built in (apparently the factory system is over your license plate, next to the light.) The mirror comes with a 6ft wire that runs down under your dash and a 20ft wire the you would have to snake through your head liner to the back of the truck.
http://www.brandsport.com/gntx-50-genk242.html
http://www.brandsport.com/gntx-20-nav03.html
Tags
2003, 2007, auto, box, camera, dim, f150, ford, mirror, rear, rearview, repair, replacement, truck, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
