You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Fuel filter replacement- I broke the retaining clips
I just changed the filter on my 07 expedition. I tried to be careful when lifting the both the blue pin and red pin on the double line side of the filter. As you probably know, the filter sits sideways making access to the retaining clips very difficult. I did manage to remove all the clips but broke the both in the process. I put them back in upon reinstallation of the new filter. One side of the clips are missing. Do I need to get new ones or do you think they will remain in place.,
Also on the outlet side. the metal clip was not quite in place on my first try. Fuel sprayed out as I started the vehicle up. I re-engaged the primary clamp with the special tool to reseat the line. The metal bracket or (clamp) had to be reseated to stop the leak.
I stopped by the Dealership today on an unrelated matter. I spoke with a mechanic that I deal with. Told him about the clips breaking (red and blue). He said this happens all the time, especially when non-dealer facilities such as quickly lube places. The trucks end up in the shop by tow trucks. The fuel lines come off and needs to be completely replaced. You cant just buy the flimsly clips.
Since the clips operate in conjuction with other plastic keepers, I was thinking of just using tie wraps or other devices to keep the secondary clip from disengaging which may allow the fuel line to come off.
I can say to my knowledge, the new style was put inplace because it is completely rebuild able. Infact most shops have the new ends. NAPA carries them also. I dont know what that mechanic is talking about, replaceing the whole line. I would buy a new end, and install it.
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis http://www.youtube.com/watch?v=pibt-TVgAx4
40 GMC truck, Mustang II, SBC.
Sig Sauer P229 Two tone.
Here is a photo pf the clips I am talking about, so we are on the same page, and not talking about 2 different ends. This photo is of the new rebuildable ends...
__________________
That looks like it. I will go to NAPA tommorow and get the fitting. How does the fitting come off? I ask because I don't want to damage it more. Once I have the fitting off the filter, does it simply slip off the line or is there a method to it?
