Removal of intake manifold on 5.4L - Page 3 - Ford Truck Enthusiasts Forums
Old 11-21-2014, 07:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
  #31
Old 05-10-2011, 10:58 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
yea, i did both sides also..... i have made gaskets for LOTS of stuff, no problem.. ask at Auto Zone or NAPA and they can get you on the right track. Just a compressed fiber/ glue/ paper type material.. dont use cork.
  #32
Old 05-10-2011, 11:38 PM
jhammer30 jhammer30 is offline
jhammer30 is starting off with a positive reputation.
I was just doing some prep work cleaning up the crossover tube itself, and I noticed two points of corrosion about the size of a pencil eraser and fairly deep on the thermostat side. They are right on the seal line, but like I said earlier there was no leak on that side. Is this something that I should ensure a little more RTV gets to those spots or should I just break down and get new parts? I can take pictures but I'm not sure how to post them right now.
  #33
Old 05-11-2011, 12:04 AM
steve(ill)'s Avatar
or fill the "hole" with epoxy and file smooth. IF its only "skin" deep, file the flange flat to clean it up.
  #34
Old 09-28-2011, 07:18 PM
fastmax1 fastmax1 is offline
fastmax1 is starting off with a positive reputation.
Quote:
Originally Posted by steve(ill) View Post
im not sure you can get to all the bolts without taking the manifold off. seems like i looked with a mirror and couple were not accessable. look at the cross over in the photo above... 3 small bolts on that side.
Hi All. I just did one of these for the same problem. I thought for a while before I pulled the intake (because of that one bolt that you cant reach) and came up with a little shortcut. You can see the bolt from the top (bottom of the bolt, not the head of it) so I drilled a small hole in it and then tapped in a T10 torx. I got the bolt to back out and back in with the torx driver. The vehicle hasnt had any problems so far (10,000 kms or so). Worse case senario was that the intake would have to come off anyways so I thought I would try it and it did work. Just thought I'd share. Good luck to all with this repair.
  #35
Old 10-02-2011, 11:48 PM
marv02's Avatar
marv02 marv02 is offline
marv02 is starting off with a positive reputation.
Question
My 5.4 is leaking at the long Hard line thats under the intake back side of the motor were it meets the rubber hose I think to replace the hard line with a rubber hose.
I have the intake off.
I have a 1986 vett and it still has most of the OEM rubber hose still so they last.
My 2001 Ex has 104000 on it I would think the rubber hose just mite last longer than the hard line.
All the rubber hoses still look new.
  #36
Old 11-25-2011, 03:03 PM
tejano40 tejano40 is offline
tejano40 is starting off with a positive reputation.
5.4 fi50 2001 coolant crossover
i took off 6 bolts 5 from the underside and one on top but it looks like theres another bolt or stud holding that crossover on. it is located on the left side of the crossover. please help only transportation i got. thanks
  #37
Old 11-25-2011, 11:07 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
kbsupercrew is starting off with a positive reputation.
2000 f150 5.4 hope these help
  #38
Old 11-26-2011, 04:21 PM
intake manifold removal
thanks for your help got the darn thing off not that hard just time consumming.. this is a great blog very knowledgable people here. thanks again...
  #39
Old 11-27-2011, 11:42 AM
magikal_dragons magikal_dragons is offline
magikal_dragons is starting off with a positive reputation.
2001 5.4L Triton Coolant Leak @ Crossover
Thanks for the post! I have all but one bolt out and thought the crossover would detach without taking the intake off, but it seems impossible. A lot more work than I was anticipating, as well as more money. Any suggestions on what else to go ahead and replace while I have it off? Is it wise to attempt to clean any/all parts I can get to? Will cleaning anything cause more problems?
  #40
Old 11-27-2011, 12:03 PM
marv02's Avatar
Heads Up I changed the plugs out with the intake off it makes it very easy might as well do it now.
If you dont and have to change the plugs out latter you going to kick your self in the butt and wished you did when the intake was off.
I also found use a Green Scocth brit pad to clean the mating surfaces where the intake maniifold mate it give you a nice clean surface I also used Brake cleaner to wash things off and apaper towle to wipe things down before reinstalling the New manifold back on the motor.
I used some RTV where the water passages on the manifold to make sure it dont leak but up to you, Ialso would let the car sit overnight before adding Collent back in the motor to give the RTV time to set up and get a good seal.
It dont mather what the RTV package said you can add coolent Oil Ect after 2 hours Dont do it let sit over night.
Next tip use some dish soap on the Injectors O rings so they slide in the intake easy and so they wont tear as easy.
Double cheeck everything before firing up the motor and going for a drive.
  #41
Old 11-28-2011, 05:59 PM
isenegger's Avatar
isenegger isenegger is offline
isenegger is starting off with a positive reputation.
i think my intake manifold just took a crap. i noticed over the weekend i smelt coolant. never got hot or anything. just a few min ago i went to drive the truck for the 1st time today and when i backed out of the drive i seen a puddle. i checked the puddle and it looked like water but was kinda oily/sticky like coolant. sure enough i popped the hood and there is coolant on the drivers side of the intake by the cops. it seemed to run down the front of the engine and dripped on the ground. so im guessing to just buy a new dorman intake manifold and take it to a shop and drop it off. i dont have time to change it myself right now.
  #42
Old 12-30-2011, 11:05 PM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputation
I'm also in need of a new intake. Are the Dormans acceptable or should I go with Motorcraft? Gaskets I know I am going to go OEM.
This is probably obvious but do I need the lower intake? Or only the upper intake?
  #43
Old 02-04-2012, 07:25 PM
DogBox DogBox is offline
DogBox is starting off with a positive reputation.
Thanks All
My first post on this forum to say thanks, especially to Steve, but to all of you for posting on here on how to fix the intake manifold problem.
I had the P0301 and P0125 codes and didn't realise they were related. I changed the COP on cylinder 1 and at the same time thought I would do the thermostat. After filling up with coolant I saw steam coming from under the hood and along with the obvious misfire after a few miles - i pulled over and saw coolant leaking from the coolant cross-over next to cylinder 1. Limped home and found this posting.
I read and re-read and then began the tear down - fairly convinced that I had the exact same problem. I pulled the trigger on a new manifold (Dorman) so that it would be here by the time I dis-mantled everything. I was a little scared at first but part by part the whole thing came apart fairly easily - even the COPs weren't too bad. I will replace all COPs as well as injectors. Plugs were done by dealer when I bought it 18 months ago. I cleaned the throttle body and now I need to wait for injectors to arrive and I will clean the gasket surfaces in the meantime.
In a way I'm pleased to have this happen and be able to fix it and replace injectors and COPs, and clean the throttle body while I'm in there. I'll have a new manifold too that hopefully will last another 100K. I'll check the IAC and EGR stuff and that coolant pipe from the back of the water pump too when I put it back together.
Maybe the $400 I saved on the Motorcraft Intake Manifold and the $650 I was quoted in labor will go towards a TrueTrac and gears now.
Photos:-
Ford Expedition Intake Manifold Replacement - a set on Flickr
  #44
Old 02-04-2012, 09:22 PM
steve(ill)'s Avatar
those are some nice photos--- good job!
  #45
Old 02-08-2012, 01:31 AM
Holy Cow! She works! It's back together and purring nicely. I just need to top off the coolant and I'm good to go.
1988 F350 7.3 IDI Captrjo Vehicles for Sale 1 04-23-2016 10:03 PM
PCV valve description steve(ill) 2004 - 2008 F150 3 02-23-2016 07:02 PM
1997 Explorer P0171 & P0174 OBDII Codes 04FordHarleyF250 Explorer, Sport Trac, Mountaineer & Aviator 7 01-07-2013 11:49 AM
Cheap rocker panel repairs steve(ill) 1997 - 2003 F150 0 11-12-2012 08:49 PM
Replacing intake manifold on a 5.4 Superdave Modular V8 (4.6L, 5.4L) 6 03-03-2010 04:10 AM
Tags
150, 2005, 54, 54l, air, f150, ford, intake, leaks, manifold, motor, removal, remove, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
