Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-13-2009, 07:26 AM
E150 E150 is offline
E150 is starting off with a positive reputation.
4.2l noise
Good morning. I have a 1998 E 250 4.2l V6 , 4EOD tranny. I have not read every post on this forum, but searching for 4.2l engine noise sure gets you alot of reading material ! Here's my noise problem for the experts. This motor has 15,000 on a rebuild. A crankshaft kit with connecting rods, new pistons, rebuilt cylinder heads, and upper and lower intakes decarboned. My noise started around 8,000 miles. The noise does not sound like rod bearing noise, but the frequency does. It's more like a loud pinging or possibly knocking. The noise happens only under acceleration and with the slightest release of the throttle the noise instantly goes away. It does not happen at all revving the engine in park or neutral. I just found a very interesting thing this weekend. I tried to power brake and run the revs up in drive and could not get the noise to occur. However, when I power broke in reverse the noise was very much there. Very predictably there. I'm now not sure if I have an engine noise, tranny noise or a strange rattle, (exhaust?) Any thoughts anyone? Thank you in advance.
  #2 (permalink)
Old 09-14-2009, 12:07 PM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, i have no explanation but it is worth checking that engine lift brackets are not loose as i have read that some time they rattle. bokker.
  #3 (permalink)
Old 09-14-2009, 02:10 PM
BrianA's Avatar
BrianA BrianA is online now
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
If you put the transmission in a different gear when the noise is occurring does the frequency change? If the noise occurs at 3000 rpm in drive, does it occur at 3000 rpm in second and low?
Trying to get to this:
Is it related to engine rpm, or transmission rpm?
Can you put the van on a lift and recreate the problem?
If so, a mechanic's stethascope might just be the ticket to isolating the source of the noise.
(on a side note- a very under utilized tool in my opinion.)
I suspect it might be torque converter / transmission.
How many miles on it?
Have you kept the fluid changed in the transmission?
edit to add: some reports of engine lift bracket bolts working loose and rattling.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Tags
1998 , 2004 , 42 , engine , f150 , ford , kit , knock , knocking , noise , noisey , pinging , rattle , rebuild , torque , van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
